5040
mashermike View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mashermike Quote  Post ReplyReply Direct Link To This Post Topic: 5040
    Posted: 07 Apr 2010 at 6:01pm
I'm looking at buying (cheap) a 5040 with a worn out engine. I found the parts no problem. My question, can this engine be rebuilt in the chassis? (new sleeves/pistons)
I've rebuilt gas engines before but never a diesel....and never re-sleeved a block.
Thanks,
Mike
Dave(NEPA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave(NEPA) Quote  Post ReplyReply Direct Link To This Post Posted: 07 Apr 2010 at 6:47pm
If you have or can borrow a sleeve puller you can get sleeves out with the engine in.  For the cost and trouble of doing a rebuild I'd go all the way and get the crank machined as well as the cam bearings changed, I tried to go cheap on my Dad's C and we ended up having to get new bearings for the mains anyway, I thought they looked good, machinist said otherwise.
Post Options Post Options   Thanks (0) Thanks(0)   Quote mashermike Quote  Post ReplyReply Direct Link To This Post Posted: 08 Apr 2010 at 5:04am
Thanks Dave, makes sense  on crank and cam bearings. Did you do anything to the head?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave(NEPA) Quote  Post ReplyReply Direct Link To This Post Posted: 08 Apr 2010 at 8:20pm
Yeah, I pulled everything apart and cleaned it, new valves, springs and guides, spent a few hours with the old valves and some lapping compound to make sure the new valves seated okay.  we should get the crank back tomorrow, it was expensive, but once it's broken in it will hopefully outlast me.
