magneto
dirtyredcub View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dirtyredcub Quote  Post ReplyReply Direct Link To This Post Topic: magneto
    Posted: 06 Apr 2010 at 11:58pm
any body got advice before i tear my magneto apart to replace the coil? what is the points gap? do you static time it like a farmall cub? it is a 1949 model c, thanks
trhod12 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote trhod12 Quote  Post ReplyReply Direct Link To This Post Posted: 07 Apr 2010 at 4:50am
Here is a real good explanation about the magneto:
The point gap, if I am not mistake, is 0.020.
Hope this helps
Post Options Post Options   Thanks (0) Thanks(0)   Quote dirtyredcub Quote  Post ReplyReply Direct Link To This Post Posted: 08 Apr 2010 at 10:31pm
thanks  good info. i got the magneto coil and it does not look exactly like the one on the tractor. the magneto is fairbanks morse x-4 b-3. is that the usual magneto for a 49 "c"? and how do you get the metal gear off to clean the insides? i took the c ring off but couldn't get the gear to slide at all. any help is greatly appreciated!
This page was generated in 0.139 seconds.
