wc rear end
farmer_rob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote farmer_rob Quote  Post ReplyReply Direct Link To This Post Topic: wc rear end
    Posted: 05 Apr 2010 at 5:16pm
i have a chance to pick up a styled wc but im not sure what yr it is. it has the orignals tires on it yet  but they need replacing. the motor is stuck but the trans is free. my question is would the wc rear end bolt up to a wd45. if so how much less weight would the wc rear be. another question would the gearing be any different such as first being faster or slower.
thanks in advance
if farming was easy everybody would be doing it
MNLonnie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNLonnie Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2010 at 5:29pm
I think you would have to swap everything behind the motor to get a WC in a WD45.
Post Options Post Options   Thanks (0) Thanks(0)   Quote farmer_rob Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2010 at 5:59pm
ok the only draw  back i would see is that id lose the foot brake deal  .. it should be close im thinking
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNLonnie Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2010 at 6:10pm
You would lose the hand clutch and I'm not sure what a WC has for hydraulics.
Gary in da UP View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary in da UP Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2010 at 6:36pm
 They are both orange, other than that they share very little in the way of parts that interchange . Next time you are at a tractor show check them out and you can see for yourself.
OrangeKiwi(NZ) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote OrangeKiwi(NZ) Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2010 at 6:53pm
Why would you want to ? It would be like going back 10 years in time.
Post Options Post Options   Thanks (0) Thanks(0)   Quote farmer_rob Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2010 at 7:41pm
well i had heard that some guys use a rear end out of a RC and swap in.. but maybe that was just the diff.. suppose to be lighter.. just going by hear -say
powertech84 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote powertech84 Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2010 at 7:54pm
Most people just swap the gears, not the rear end.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNLonnie Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2010 at 8:07pm
I would guess that the RC has lower gears because of the motor and they use those in a WC, but not a WD.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary in da UP Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2010 at 8:08pm
 What does an RC have to do with a WD45? RC's and Hi-crop WC's have a lower gear ratio ring/pinion . Thats all. They won't work in WD or WD45 diff's.
Post Options Post Options   Thanks (0) Thanks(0)   Quote farmer_rob Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2010 at 9:10pm
it would give a lower gear which would help out a 45 with 38's by keeping the speed down below the whisle
NNYACAL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NNYACAL Quote  Post ReplyReply Direct Link To This Post Posted: 07 Apr 2010 at 10:21am
Rob If you are looking for low gearing I saw on e-bay a couple of weks ago where a man took a WC, removed the rear housing and differential and installed a wd45 trans axle behind the wc transmission which gave him 16 forward speeds and a double reduction in low  thought this was a good set-up so i called the guy and he explained how he did it by removing the in-out box on the wc and installing a short slip/spline between the two transmissions.
NNYACAL
G,IB,B,C,CA,RC,WC,WF,WD,WD45,D14,D17SERIES 1,2,4
Post Options Post Options   Thanks (0) Thanks(0)   Quote farmer_rob Quote  Post ReplyReply Direct Link To This Post Posted: 07 Apr 2010 at 5:39pm
wow with that set up a guy wouldnt need to speed big bucks on a motor after he installs 38's for pulling. but you would have to run in the open class or something like that
