Lift Latch Question
AaronB View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronB Quote  Post ReplyReply Direct Link To This Post Topic: Lift Latch Question
    Posted: 04 Apr 2010 at 11:15am
Does anyone know what material the lift latches are made from on a WD?  They look to be cast iron, but could be cast steel.  One of mine has a broken ear and I need to know what to weld it with.  Any suggestions are appreciated.  Thanks!
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2010 at 11:49am
Aaron, get yourself a known piece of cast iron and a piece of steel. Take turns shoving them into a grinding wheel and take note of the sparks that come off. Once you are familiar with what the sparks look like on each, grind on the spot that needs welding to tell what kind of material it is. I would bet on steel as a forging would be much stronger than a casting. Charlie
This page was generated in 0.324 seconds.
