wheelybars |
Ronnie
Joined: 23 Mar 2014 Location: New Brighton Points: 557 |
Topic: wheelybarsPosted: 20 Apr 2015 at 1:41pm |
Can u guys share some pictures of wheelbars for a 190 or 200. I was just informed that all tractors got to have them to pull with my club due to inserence reasons. Thanks
DrAllis
Posted: 21 Apr 2015 at 8:18am |
All depends on how much of your original drawbar and 3 point hitch you are leaving on the tractor. You could attach to the side of the torsion bar framework where the sway blocks attach to, if that stuff is still there.
Ronnie
Posted: 21 Apr 2015 at 11:07am |
Well I have the pto and the drawbar but no 3point arms or sway blocks and the drawbar is adjustable
DrAllis
Posted: 21 Apr 2015 at 12:37pm |
Well then, attach to where the sway blocks went. Make sure they extend back as far as the rear tire diameter and no more than 9 inches off the ground and capable of supporting the weight of the tractor. Maybe make them adjustable in height for loading/unloading from a trailer.
2wise4agm
Joined: 19 Aug 2011 Location: Smithton, MO Points: 538 |
Posted: 21 Apr 2015 at 8:20pm |
If you will send me your email I can send you some pics of mine that I have on my phone.
Ronnie
Posted: 21 Apr 2015 at 8:46pm |
Sent u a pm 2wise4agm
2wise4agm
Posted: 22 Apr 2015 at 4:43pm |
Beirnesy
Joined: 30 Jun 2012 Location: Mid Western Ont Points: 351 |
Posted: 22 Apr 2015 at 8:13pm |
A question for 2wise4agm: Are the u-bolt axle hubs AC specific/ or will another tractor brand work on the AC axle? I am not having any luck finding a set and I prefer not to weld on a 9 bolt hub and cut off axle stub. Thanks
1969 220,1967 190DXT,1968 190DXT, LGT's 710,,716
2wise4agm
Posted: 22 Apr 2015 at 8:17pm |
I found my hubs and wheels in a salvage yard. They are not AC specific. Don't remember who mine are made by, but they are aftermarket.
7040
Joined: 11 Aug 2013 Location: newglarus wi Points: 418 |
Posted: 23 Apr 2015 at 12:36am |
Beirnsy what part of the country are you in I have one good one and one that I tore the key off mine were dmi brand.i have been told it is repairable. I switched too weldonhubs. Also I was told Oliver used a lot of that size hub not sure if that's true.
Beirnesy
Posted: 23 Apr 2015 at 5:06pm |
I am in SW Ontario, I have thought of the Oliver style, the Oliver keyway is tapered. My Oliver collecting neighbours say I could grind keyway square.
Larry(OH)
Joined: 11 Sep 2009 Location: Shreve Ohio Points: 1580 |
Posted: 24 Apr 2015 at 5:39am |
Check these guys out. Real nice stuff
http://www.capbrosmotorsports.com/index.html |
'40 WC puller, '65 770 Ollie
*ALLIS EXPRESS contact* I can explain it to you, BUT I cannot understand it for you!! |
