Loader not working properly.
180shane View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 180shane Quote  Post ReplyReply Direct Link To This Post Topic: Loader not working properly.
    Posted: 16 Apr 2015 at 6:15am
On my 180 when you pull the lever back to tilt the forks it doesn't move. It makes like a vibrating sound but won't move. The bush hog loader raises and lowers just fine but the tilt will not move. Thanks in advance.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 16 Apr 2015 at 6:30am
Couppler problems, not pluged all the way in, bad point, not a matched set or worn out set.   MACK
Rick View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rick Quote  Post ReplyReply Direct Link To This Post Posted: 16 Apr 2015 at 6:38am
Plenty hydraulic oil?   Rick
Post Options Post Options   Thanks (0) Thanks(0)   Quote 180shane Quote  Post ReplyReply Direct Link To This Post Posted: 17 Apr 2015 at 8:56pm
Just checked, the fluids and they were good and the couplers were engaged fully. Still no luck.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 17 Apr 2015 at 9:14pm
Do you have 2 remotes running the loader? One for lift and one for tilt?
SHAMELESS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SHAMELESS Quote  Post ReplyReply Direct Link To This Post Posted: 17 Apr 2015 at 9:19pm
like Mack says...and maybe change the hyd ends...sounds like it's starving for fluid!
kinghunter View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kinghunter Quote  Post ReplyReply Direct Link To This Post Posted: 17 Apr 2015 at 9:57pm
i had this same problem and it ended up being the ends i couldnt believe it because i couldnt tell defference between new and old but i changed them and it works great.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 180shane Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2015 at 7:56pm
Are you guys talking about changing the female ends on the tractor or the male ends on the hoses?
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2015 at 8:11pm
yes
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2015 at 8:12pm
you could do some trouble shooting and switch controls for tilt and raise, see if problem follows hoses.
slip knot View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote slip knot Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2015 at 9:57pm
Had the same problem with my 500 loader. found one of the quick connects would let oil flow one direction but not the other. This was a while back and my hairs  just aout grown back out. A real pita.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 180shane Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2015 at 9:02pm
Thanks everyone for the help. Ended up being the male end of the hose . Replaced and works wonderful now.
This page was generated in 2.996 seconds.
