Woods Mower Mounting Question
PA Bill View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote PA Bill Quote  Post ReplyReply Direct Link To This Post Topic: Woods Mower Mounting Question
    Posted: 01 Apr 2010 at 4:40pm
A guy not far from me has a Woods L59 mower he took off of a B that he'll make me a good deal on. Comes with all the brackets off the B.
I'd like to use it on my CA. Will the brackets off the B work to mount the mower on the CA or will I have to get new ones?
Thanks.
RyanTN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote RyanTN Quote  Post ReplyReply Direct Link To This Post Posted: 01 Apr 2010 at 4:49pm
Bill, A CA has a wider distance between the finals.  You will need to lengthen or replace that mount.  I think everything else should work.  Here is a link to the manuals on the Woods site to double check.  The ones you want are "L59CA, L306CA" and "L59 AC B&C..."
Edited by RyanTN - 01 Apr 2010 at 5:03pm
norm [ind] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote norm [ind] Quote  Post ReplyReply Direct Link To This Post Posted: 01 Apr 2010 at 7:53pm
 for best results but the correct one from woods
morton(pa) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote morton(pa) Quote  Post ReplyReply Direct Link To This Post Posted: 01 Apr 2010 at 8:39pm
Depending on which style mounting brackets he has, it may or may not work. I know there are some mounting brackets are interchangeable with the B and C, but I'm not sure about the CA. Better check the measurements on them first. Some are adjustable, others are not.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 01 Apr 2010 at 8:59pm
I have an L59 that has a 3 part adjustable bracket for the "push bar" . Either end has a flange that bolts to the finals, and the center piece has the idler pulleys and connects the 2 outside pieces together. This is a factory set up from Woods. I used it on the 51 CA until 3 years ago, and now have it on my 38 B. If the "push bar" is one piece it will not swap out.
This page was generated in 0.359 seconds.
