Rod bearings.
joegrgraham View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote joegrgraham Quote  Post ReplyReply Direct Link To This Post Topic: Rod bearings.
    Posted: 01 Apr 2010 at 2:48pm
Why is it that a brand new set of +20 thou rod bearings are around 6 - 7 thou THINNER than an old set of +10 thou ones I've just pulled out of the scrap bin???????????
If it seems like a good idea, do it. It's easier to apologise than to get permission.
mlpankey View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 01 Apr 2010 at 3:11pm
have you wiped the new bearings?
Dick L View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 01 Apr 2010 at 3:14pm
One or the other was mismarked. One of those details I gripe about all the time. Measure every part before installing.
(Brand new parts should not need to be measured) (Ya, Right) as you just found out.
Post Options Post Options   Thanks (0) Thanks(0)   Quote joegrgraham Quote  Post ReplyReply Direct Link To This Post Posted: 01 Apr 2010 at 4:04pm
Dick L, what should be the correct thickness for a new rod bearing, and the mains as well, if I've got the correct figures, I can work out the rest. Many Thanks.
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 01 Apr 2010 at 4:16pm
I am not dick but why would you be concerned with overall thicknes of bearings . The rod with the bearing in it and  the bottom cap torqued should be .002 larger than the rod journal . If thats right you put it on the rod journal and with a feeler gauge you make sure you have some side clearance between the rod and the crank jornal throw .  for the oem guys the book says .004-.007 side clearance. you know you shim between the rod and rod cap unless you had them machined so that you dont use shims right.
Edited by mlpankey - 01 Apr 2010 at 4:18pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 01 Apr 2010 at 4:35pm
Take a look at the pictures. this one of the ways I check bearings.
This page was generated in 0.199 seconds.
