wd 45 torque tube shaft
bsb45chalm View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bsb45chalm Quote  Post ReplyReply Direct Link To This Post Topic: wd 45 torque tube shaft
    Posted: 30 Mar 2010 at 8:30pm
replaced rear bearing +seals  using front bearing again seem fine when put together with snap rings on drive gear and in the housing  with coupling flange in with snap ring on is it normal for 1/8" play in shaft?? thank you for the time and hopfully a reply Thanks always for the insight  I read the book but no info>>
skipwelte View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote skipwelte Quote  Post ReplyReply Direct Link To This Post Posted: 31 Mar 2010 at 11:13am
1/8 inch is a lot.  Id recheck and see if you can get end play down to less than a 1/16th.
