190 vs. 180
Bad habit View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bad habit Quote  Post ReplyReply Direct Link To This Post Topic: 190 vs. 180
    Posted: 17 Mar 2015 at 10:31pm
Hi...what are the speed differences in the 180 to 190 tractor trans in road gear...
How much faster is the 180 vs the 190...30% ?? Is the 180 the better tractor to built for the llss class? Thanks for the help and opinions.
O.P.S. Heads View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote O.P.S. Heads Quote  Post ReplyReply Direct Link To This Post Posted: 17 Mar 2015 at 11:17pm
180 - 185 is right at 20% faster with the same size tire.
Anymore I'm not sure it matters as both drive lines have to be sped up way over road gear in a LLSS class to be competitive. If you are making gears for a 180 you can do the same for a 190, just a faster ratio. The 190 has a little more heft in the rear and finals I think. That is the next foreseeable issue as time goes on and power increases with the 180's in that class - final drives.
Is that you Jerry? If so send me a pm. I have a question about the oil pump bracket for the older 301 block.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 19 Mar 2015 at 8:02am
I have overdrive gear boxes for 180-200. Alot less expensive and easer than changing gears in trans. to get the Ro. you may need. up to 35% over. MACK  660 663 9173
