8010 help!!!
clint View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote clint Quote  Post ReplyReply Direct Link To This Post Topic: 8010 help!!!
    Posted: 29 Mar 2010 at 9:00pm
the volt light came on- alt was squealing- took to town- tested at 11volts- was an delco with only the one wire wired- the prongs were sealed by a rubber piece- was working fine until the other day
they tested the new one with just the one wire- 12 volts
with the prongs hooked- 15
with the prongs hooked on mine- still 11
i took the new one home- light still on- maybe needs to run for a while? i had it running about 20 minutes?
what else could be wrong? a voltage regulator? where is it on the tractor?
Our farms stuff: agco gt55, AA 8775, 8765, 6080, 185, 180, 175, 170, d15, d14, d14, wd, wd, wd, g, F3, L3, R62
Post Options Post Options   Thanks (0) Thanks(0)   Quote clint Quote  Post ReplyReply Direct Link To This Post Posted: 30 Mar 2010 at 7:25am
bump
the alt on it was 1105 631 replaced with the same
Post Options Post Options   Thanks (0) Thanks(0)   Quote clint Quote  Post ReplyReply Direct Link To This Post Posted: 30 Mar 2010 at 7:31am
the agco dealer says 1105 423 is the proper one- what is the difference?
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 30 Mar 2010 at 8:10am
SOMEONE replaced the oem alt with a one wire which is ok, the plug keeps one from trying to plug in wires, however the prongs are there it is just connected to the rt terminal 12v and the other is diode switched;  the reason it was squealing was belt was loose, battery or wire is bad and calling for max output is my guess.    Of course the alt only put out 12 v w/o wires connected that is what it is supposed to do.  The reason the light is on is probably the reason the alt you pulled off was squealing - the batt is not taking a charge or is shorted?   Just a possibility  from experience.
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 30 Mar 2010 at 8:13am
forgot to reply - the voltage regulator is internal - in the alternator
Post Options Post Options   Thanks (0) Thanks(0)   Quote clint Quote  Post ReplyReply Direct Link To This Post Posted: 30 Mar 2010 at 8:16am
tbran- would it hurt anything to plug the wires in the alt?
