sheet metal
ACscott View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACscott Quote  Post ReplyReply Direct Link To This Post Topic: sheet metal
    Posted: 29 Mar 2010 at 2:47pm
is the sheet metal on the d14 the same as the d15 like the side panels under the gas tank and the front grill assembly. thanks in advance
snowman(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote snowman(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 29 Mar 2010 at 8:00pm
Don't know about the side panels, but the front nose cone and grille is different between the 14 and 15, with the 15 being wider.
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 29 Mar 2010 at 9:29pm
A Series I D15 is the same I believe (except for the diesels).  But as mentioned above, the series II is wider.  Panels under the gas tank would probably be the same though.
JoeO(CMO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeO(CMO) Quote  Post ReplyReply Direct Link To This Post Posted: 30 Mar 2010 at 7:02am
All D15's are wider than the D14
Edited by JoeO(CMO) - 30 Mar 2010 at 7:04am
