CA Ring Gear Problem
GT in Indiana View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GT in Indiana Quote  Post ReplyReply Direct Link To This Post Topic: CA Ring Gear Problem
    Posted: 28 Mar 2010 at 6:52pm
My buddy has a 51' CA that we think has a bad spot on the ring gear.  Seems like when you shut it off in neutral, the engine stops in the same spot.  Then the starter won't engage, but if you take the starter out and put it back in, it will start.
We have been shuttig it off in gear and that works when you remember to do it, bit it's becoming a real pain.  Wanted to see what you guys think before cracking it open.  Are we missing something?
Gerald
1955 WD45 we like to call Ruby
norm [ind] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote norm [ind] Quote  Post ReplyReply Direct Link To This Post Posted: 28 Mar 2010 at 6:59pm
  all motors stop in the same place  that is the reason the ring gears go bad  ring gear bad  starter bendix is worn also
B26240 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote B26240 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Mar 2010 at 6:59pm
Sounds like  a bad ring gear, not that bad a job to change, they only cost  $50 or so.
Allen Dilg View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allen Dilg Quote  Post ReplyReply Direct Link To This Post Posted: 28 Mar 2010 at 8:40pm
  GT  I would remove the starter and inspect the ging gear with a light.  The fact that when you remove the starter and reinstall it it works, I would check the small spring on the bendix and lube.
Michael Welch View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Michael Welch Quote  Post ReplyReply Direct Link To This Post Posted: 28 Mar 2010 at 8:50pm
Hey GT thanks for the call. I got home about 8:15 pm. My trailer is 33.5'' tall the tractor was 13' 6'' to the cab & another inch for the exhaust. It was a good trip.
Cal View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Cal Quote  Post ReplyReply Direct Link To This Post Posted: 28 Mar 2010 at 8:52pm
I have heard of old timers splitting the tractor just enough to access the ring gear and heating it with a torch and when hot enough turning it to a new location let it cool and you have a new spot for it to start and stop . Cal in Ct.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 28 Mar 2010 at 9:39pm
you can remove the gear and turn it 90 degrees, but your not going to do it thru a 3 inch hole. you will need to pull the motor off the torque tube and remove the flywheel to do it... If you stop and wont engage, rock the tractor in gear and move the motor/ crank a few inches to get to a better spot on the gear.... I have put in 3-4 of the $50 gears. It really is not a bad job. With an engine hoist on the motor, and hanging the back end off a beam in the barn ( strap around the torque tube), you can have it apart  in a couple hours easy.
Post Options Post Options   Thanks (0) Thanks(0)   Quote GT in Indiana Quote  Post ReplyReply Direct Link To This Post Posted: 29 Mar 2010 at 6:55pm
Thank you all for your responses.
Greatly appreciated!
GT
Dusty MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dusty MI Quote  Post ReplyReply Direct Link To This Post Posted: 29 Mar 2010 at 7:04pm
I'm with Allen, do what's easy first.
Dusty
