Simplicity Landlord questions
BennyLumpkin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BennyLumpkin Quote  Post ReplyReply Direct Link To This Post Topic: Simplicity Landlord questions
    Posted: 19 Feb 2015 at 10:51am
Possibly trading my cub 124 for a Landlord. Has just a deck, hydro lift and rear lift. Worth it? How hard is it to find a blade and blower for it? Anything I should look at on it? Never messed with Allis or Simplicity garden tractors. It's one that looks like a B1 Allis. Thanks.
Central PA Allis Express
1934 WC254
1945 WF
1945 WC135755
1951 WD68085
1953 WD45-150217
1957 WD45D-230744D
B110
Post Options Post Options   Thanks (0) Thanks(0)   Quote BennyLumpkin Quote  Post ReplyReply Direct Link To This Post Posted: 19 Feb 2015 at 10:55am
1934 WC254
1945 WF
1945 WC135755
1951 WD68085
1953 WD45-150217
1957 WD45D-230744D
B110
talntedmrgreen View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote talntedmrgreen Quote  Post ReplyReply Direct Link To This Post Posted: 19 Feb 2015 at 3:33pm
Great looking tractor...well worth the asking price, with the OEM rear light and hydrolift.  Attachments are extremely easy to find.
Patterson B1*B1/B1Forklift*B10*BigTen/B1Loader*B110*B208*B206*616*Homelite T16H/T8/T7/RM7E*Landlord/Loader/Trencher*Broadmoor717*Serf525*2110*7790*Legacy XL*Twin 20*Squire9*Squire6*JCPenny 494
AaronSEIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronSEIA Quote  Post ReplyReply Direct Link To This Post Posted: 19 Feb 2015 at 5:58pm
The hydrolift is worth nearly $300 on it's own.  Great looking machine.  The big thing to check is the bevel gear box.  They run a solid drive shaft from the engine back to a gearbox roughly under your butt on the seat.  One side runs the tranny and one side runs the deck.  Easily rebuilt, but bearings and seals add up to some good money.  Flip the seat up and you can check the play on the side shaft.  Attachments are very readily available and are pretty easy to find on the east coast.  A 3 angle blade sould run around $100 or so.  They have a 5 angle adjust from the seat trips like a modern snowplow blade that runs around $150 or so.  A good single belt blower runs $100-$200 ish.  A 3 belt which is more complicated and can't be shut off from the seat is $25-$100.  Everyone wants the single.
AaronSEIA
Post Options Post Options   Thanks (0) Thanks(0)   Quote BennyLumpkin Quote  Post ReplyReply Direct Link To This Post Posted: 19 Feb 2015 at 8:36pm
Looks like I need to get trading lol
1934 WC254
1945 WF
1945 WC135755
1951 WD68085
1953 WD45-150217
1957 WD45D-230744D
B110
Post Options Post Options   Thanks (0) Thanks(0)   Quote BennyLumpkin Quote  Post ReplyReply Direct Link To This Post Posted: 19 Feb 2015 at 8:53pm
Blower
Which style is this? Will it work?
1934 WC254
1945 WF
1945 WC135755
1951 WD68085
1953 WD45-150217
1957 WD45D-230744D
B110
ACmowerguy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACmowerguy Quote  Post ReplyReply Direct Link To This Post Posted: 19 Feb 2015 at 9:26pm
Yes that is the correct blower for the '60s Landlords. It is the single belt blower. Make sure you get any attaching rods or linkages he has for it or else you will have to make them.
Post Options Post Options   Thanks (0) Thanks(0)   Quote BennyLumpkin Quote  Post ReplyReply Direct Link To This Post Posted: 19 Feb 2015 at 9:29pm
Awesome. Now to find a blade and I'll be golden. I'll use a blade more often anyway
1934 WC254
1945 WF
1945 WC135755
1951 WD68085
1953 WD45-150217
1957 WD45D-230744D
B110
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronSEIA Quote  Post ReplyReply Direct Link To This Post Posted: 20 Feb 2015 at 6:57am
I've got a 42" blade I'd sell, but Iowa is a bit of a trip from PA.  There is a Facebook page for us mower guys, and a great mower club on line as well.  I've been using a blade but got a blower this year.  Blade hasn't been used once.  The blower is just awesome.
AaronSEIA
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 20 Feb 2015 at 2:23pm
I have a Sears blade that bolts right on 7016. Have the brackets for it. I believe its the same as the earlier units. Northern NJ A little closer.. LOL!
Steve@B&B
Gary in Texas View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary in Texas Quote  Post ReplyReply Direct Link To This Post Posted: 21 Feb 2015 at 4:12am
you might check with Sandy Lake Imp.
They had a few, some time ago.
Post Options Post Options   Thanks (0) Thanks(0)   Quote BennyLumpkin Quote  Post ReplyReply Direct Link To This Post Posted: 22 Feb 2015 at 2:57pm
Deal is on. Picking it up hopefully this week. I just made a deal on a blower and blade from another guy...the link above....225 for the pair sound fair??
1934 WC254
1945 WF
1945 WC135755
1951 WD68085
1953 WD45-150217
1957 WD45D-230744D
B110
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronSEIA Quote  Post ReplyReply Direct Link To This Post Posted: 22 Feb 2015 at 3:56pm
$225 for the blade and blower?  Is it the 42" or 46 blade?  As long as you have all the lift and engaging rods, you did just fine.  Make sure you get a genuine Simplicity belt for that blower.  Simplicity # 1721533sm.
AaronSEIA
Post Options Post Options   Thanks (0) Thanks(0)   Quote BennyLumpkin Quote  Post ReplyReply Direct Link To This Post Posted: 22 Feb 2015 at 4:10pm
Not sure on blade width. Does it make much of a difference? Other than a few inches or is one better than the other?
1934 WC254
1945 WF
1945 WC135755
1951 WD68085
1953 WD45-150217
1957 WD45D-230744D
B110
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronSEIA Quote  Post ReplyReply Direct Link To This Post Posted: 23 Feb 2015 at 6:06pm
The 42" blade was a 3 angle get off the seat to change setup.  The 46" blade is a 5 angle that could be changed from the seat and is spring loaded like a pickup mounted snow plow.
Here is a picture of a 42" blade on my B110.  Don't have a shot of my 46".  I'll get one of those tomorrow for you.
AaronSEIA
Post Options Post Options   Thanks (0) Thanks(0)   Quote BennyLumpkin Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2015 at 6:23pm
Doesn't much matter....he backed out of the deal. Hopefully I'll get an AC garden tractor someday
1934 WC254
1945 WF
1945 WC135755
1951 WD68085
1953 WD45-150217
1957 WD45D-230744D
B110
alleyyooper View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote alleyyooper Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2015 at 7:57am
Ya'll who want to ship large items should look into the Fastenal deal.
   Al
split51 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote split51 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2015 at 11:26am
I second the Fastenal. Cheap shipping.
1929 20-35 sn17662
B1 w/snow blade
B10 w/sickle mower
B110 w/mower deck
B110 w/tiller
B112 w/grader blade
B210 w/plo
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2015 at 1:13pm
Benny,
 To bad on the deal falling through. I have a bunch of Cubs and Cub implements, but after hanging around here for a while those 720's look like pretty nice machines!
This page was generated in 0.422 seconds.
