D19 Bull Pinion
JCinPA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JCinPA Quote  Post ReplyReply Direct Link To This Post Topic: D19 Bull Pinion
    Posted: 28 Mar 2010 at 6:04pm
Need help fellas.   I'm lookin for a Bull Pinion For My D19.  Any leads would be appreciated.  Thanks in advance.  JCinPA
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Mar 2010 at 9:49pm
Would one from a 190 work?  Just curious.
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 28 Mar 2010 at 9:54pm
I think the early straight 190 would work or an early xt gasser. Diesels xt's had a field installed updated rear end.
Wink
I am a Russian Bot
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Mar 2010 at 10:19pm
The gears on my XTD are flaking a little bit.  I am planning to rotate them so that the backside gets used.  There is still lots of metal there.
Might be sometihng for you to consider too if they are not too worn.
Post Options Post Options   Thanks (0) Thanks(0)   Quote JCinPA Quote  Post ReplyReply Direct Link To This Post Posted: 29 Mar 2010 at 4:38pm
I have been told that the bull pinion from a One Ninty will work but need to be carefull to get same tooth count or replace both sides.   I'm gonna look it over close to see if reversing is an option.  Thanks for the sugestions  JCinPA
Gary IN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary IN Quote  Post ReplyReply Direct Link To This Post Posted: 29 Mar 2010 at 8:33pm
Have a parts D-19 trans and rearend good. North East Indiana. if you can't find one closer. Gary IN
This page was generated in 0.199 seconds.
