Unstyled WC
David Terry View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote David Terry Quote  Post ReplyReply Direct Link To This Post Topic: Unstyled WC
    Posted: 15 Feb 2015 at 7:46am
I have an un-styled WC that I'm going to set up for pulling. It is a hand crank, and I think I'll need to convert to electric start. Any ideas how I go about it?
alan-nj View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote alan-nj Quote  Post ReplyReply Direct Link To This Post Posted: 15 Feb 2015 at 7:52am
are you asking how to set it up for pulling or how to convert it to electric start?
If ignorance is bliss, than happy days are here again.
1955allisca View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1955allisca Quote  Post ReplyReply Direct Link To This Post Posted: 15 Feb 2015 at 8:07am
To convert to electric start you will need a bell housing from an electric starter WC that had a starter, also flywheel may not have teeth I've never messed with one may need newer flywheel or buy a ring gear for existing flywheel.
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 15 Feb 2015 at 8:54am
Electric Start was introduced in 1938 with the 1st Styled WC.
Gary
Kip-Utah View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kip-Utah Quote  Post ReplyReply Direct Link To This Post Posted: 15 Feb 2015 at 9:15am
You need nothing more than a bellhousing from a styled WC, WD, or WD45 and the corresponding flywheel and starter. I would have a starter rebuild shop change the switch contact lump on your starter to a threaded stud and then find a place to mount an older Ford type remote mounted solenoid rather than fabricating a mechanical starter rod. Find a place to mount a 12 volt battery and you're good to go! If you are using a magneto you don't even need a generator/alternator, just charge the battery before every pull.
nborga87 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nborga87 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Feb 2015 at 12:43pm
i have a bellhousing if you are interested.
Post Options Post Options   Thanks (0) Thanks(0)   Quote David Terry Quote  Post ReplyReply Direct Link To This Post Posted: 15 Feb 2015 at 5:32pm
Kip, thanks, I had the concept right, but I wasn't sure the styled model bell housings would marry up. Thanks to all, DAve
Post Options Post Options   Thanks (0) Thanks(0)   Quote David Terry Quote  Post ReplyReply Direct Link To This Post Posted: 15 Feb 2015 at 5:36pm
I live about 3 miles from Jim Campbell's tractor salvage and he specializes in IH and Allis. I'll try him first and if no luck then I'll get back in the forum and start looking. Freight from Maryland could get costly. Thanks for the offer though, DAve
Post Options Post Options   Thanks (0) Thanks(0)   Quote David Terry Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2015 at 5:12pm
A week or so ago you offered me a WC bell housing I can use to upgrade my hand crank WC to electric start. Do you still have the housing, and is it for sale?
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2015 at 6:53pm
Don't forget a flywheel with ring gear.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2015 at 9:36pm
I can do a starter for you if interested. On occasion in between rebuilding standard starters, I'll do a starter motor for our pulling customer's. Drop a line or give us a call if interested...
Steve@B&B
bb-customcircuits.com
customcircuits@gmail.com
This page was generated in 0.224 seconds.
