Unstyled wc, help identify
JM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JM Quote  Post ReplyReply Direct Link To This Post Topic: Unstyled wc, help identify
    Posted: 28 Mar 2010 at 10:27am
My wc is serial number wc82767, I think that is a late 38.It has no holes in the hood for the small starter tank. The engine casting number is u3019-23, It had a wd manifold and air cleaner on it. I am wondering if it is still the original engine or did somebody put a wd in it? The left side of the engine has a patch plate over it and I cant see the numbers. It also has a starter and generator, but I think that has been added as the wiring for the charging system is cobbed up and incomplete. What do you guys think? Thanks.
MNLonnie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNLonnie Quote  Post ReplyReply Direct Link To This Post Posted: 28 Mar 2010 at 11:05am
The serial # would make it a 1939. Not sure on the motor.
Pipe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pipe Quote  Post ReplyReply Direct Link To This Post Posted: 28 Mar 2010 at 11:49am
 yep 39 plate on the side starter and generator should all be correct on tractor. could be a wd motor but probably is the orginal motor.
Pipe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pipe Quote  Post ReplyReply Direct Link To This Post Posted: 28 Mar 2010 at 11:51am
tractor should be a styled tractor ?
