Let's see tractors w/ Fat Back 24.5 or 30.5 x 32s |
Post Reply ![]() |
Page 12> |
Author | |||
AC7060IL ![]() Orange Level ![]() Joined: 19 Aug 2012 Location: central IL Points: 3530 |
![]() ![]() ![]() ![]() ![]() Posted: 25 Jan 2015 at 11:10am |
I always thought they looked tough. I don't have any tractors outfitted with 24.5x32s or 30.5x32s, so I've never operated any. How do they stand up on performance & wear? Please load up your pictures if you hand one. Thanks for sharing :)
Sponsored Links | |||
Calvin Schmidt ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Ontario Can. Points: 4540 |
30.5's 0n the 210.---23.1 x 34" duals on the D-21--- 20.8 x 38" radial duals on the 220
![]() ![]() Edited by Calvin Schmidt - 30 Aug 2015 at 1:35pm |
SHAMELESS ![]() Orange Level ![]() ![]() Joined: 13 Sep 2009 Location: EAST NE Points: 29486 |
that drawbar looks like it's bent "up"...is it? and how?
tbran ![]() Orange Level ![]() Joined: 14 Sep 2009 Location: Paris Tn Points: 3522 |
Beyonce' eat your heart out - those be some fine rears....
WF owner ![]() Orange Level ![]() Joined: 12 May 2013 Location: Bombay NY Points: 5013 |
They are nice rears, but Beyoncé has nothing to worry about...
Dave7060 ![]() Bronze Level ![]() Joined: 12 Nov 2009 Points: 184 |
Had 24.5-32's on my 7060. They SUCKED! Only good thing was they looked cool. They ride terrible, made the whole tractor vibrate on the road, terribly expensive, could not run duals on the drill, too wide to fit in the furrow when we still plowed and they just would not put the power to the ground like they should with out loading them or having a bunch of wheel weights. I changed over to 20.8R38's, made a new tractor out of it. I also run duals now since I could narrow it up because of my 750 Deere drill. Now with the drill when I shift from 5-6 it will pull the front end off the ground an inch or two unless I put the front weights on, 24.5-32's just slipped till they caught up. No more spinning when working ground either with the 20.8R38's. With two 24.5-32's you have 860 square inches of rubber hitting the ground. With four 20.8R38's you have 1500 square inches, that's a 47% increase I believe. My 7580 has 8 24.5-32's on it and they are alright. Lots of floatation and will put all the power to the ground easy. Only thing I don't like there is they are bad for getting flat spots if it sits a while and with clamp on duals it makes it too wide to space them out so they don't fill up with mud if we have a wet fall. I think your better off going with 650/75R32's if you want a big tire. Much flatter than the balloonish style of a regular 24.5-32, they will ride better and put more power down. 20.8R38's are a lot cheaper though. ![]() ![]() ![]() ![]() ![]() My 7060 as it sits now with the 20.8R38's |
dustinmo ![]() Orange Level Access ![]() ![]() Joined: 12 Sep 2009 Location: Auxvasse, MO Points: 2187 |
Eldon (WA) ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Spokane, WA Points: 7765 |
ALLIS EXPRESS!
This year: |
nanuk ![]() Silver Level ![]() ![]() Joined: 22 Aug 2013 Location: Saskatchewan Points: 258 |
I've considered fatties on my 7060 but I think it would be better to have worn out 20.8's and widen them as far as I can so they just miss my baler on tight turns.
the FRONTS, now, completely different story. I have the 14x16.1's three rib, and when turning, my center ribs dig a 3-4" furrow. I'd LIKE to get some 20" or so diamond treads for the front.
AC7060Pd 1975
jorstad brothers ![]() Orange Level ![]() ![]() Joined: 10 Jun 2010 Location: tioga nd Points: 473 |
remember plunder than burn
Unit3 ![]() Orange Level ![]() ![]() Joined: 17 Oct 2009 Location: NC Iowa Points: 5595 |
Wish I could play, but 20.8's are the biggest our AC's sport.
Wow, great photos. I learned that a D21 has rear lights on the back of its fenders opposed to the 210 or 220s. Dave7060, your comments about the fat tires rough ride & poorer performance is interesting. Maybe that's why most fat tire D21s were weighted down to the hilt?
DustinMo, why does your third D21's rear tires have such wide spaced lugs with a prominent center rib? Jorstad, what model is sitting in the shed by the 220, has the Fwa looking axles? I've never seen a 190 with fat tires. Is it a beach master 190? Eldon(WA), is your D21 a series I or II? Did you swap it tires to another tractor? LOL.. Thanks guys! Keep em coming.. |
DanWi ![]() Orange Level Access ![]() ![]() Joined: 18 Sep 2009 Location: wttn Points: 1921 |
190 option was a 23.1 x 30
the tractor next to the 220 is a 220 fwa and the 190 has 23.1-30 on it.
VF Farms ![]() Orange Level ![]() Joined: 24 Jan 2012 Location: Pana, IL Points: 264 |
Here's our 1977 7580 with 30.5's all original paint.
3-8550,7580,8070,8030,7010,7000,210,2-D21,2-D19,4-D17,wd's and wc's and old farm equipment
It's a Series I.....haven't figured out how to get these tires off yet LOL! Those 2 sets of inner weights and set of outer weights are intimidating me.... |
ALLIS EXPRESS!
This year: |
Jorstad, the grill sitting in the 190's cab speaks volumes.
VF Farms, your 7580 looks like a brute! How many hours on it? Eldon(WA), I vote that you unbolt the outside weights first. Everyone, would these fat tires hold more or less fluid than 20.8s, 18.4s, etc? |
and pic 3s 21 has rice and cane tires on it, it came from Arkansas Edited by dustinmo - 27 Jan 2015 at 10:14pm |
i have a 210 with weights like that on the inside and outside also
SteveM C/IL ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8612 |
Hey you just gave me hope! |
ALLIS EXPRESS!
This year: |
I believe they are rice and cane tires. |
Acelt250 ![]() Bronze Level ![]() Joined: 29 Aug 2015 Location: Stoughton wi Points: 7 |
I have a 220 with 34 in rims can any one tell me what I need to switch to get 32's on it
you will need tires rims and centers
Your other option which is not original is what I did on my D-21. It came with 18.4 x 34 and I had a good pair of 23.1 x 34 tires from a misadventure in modified tractor pulling 30 years earlier so I widened the rims to 20" and used the tires that I had. 23.1 x 34 tires are very hard to find. As was said, for 32's you need everything.
DougG ![]() Orange Level ![]() Joined: 20 Sep 2009 Location: Mo Points: 8338 |
Shameless, I'm working on a 190 XT that has the drawback bent up too, still trying to figure out how that happened!
kmorth ![]() Silver Level ![]() Joined: 09 Dec 2014 Location: Troy, MO Points: 95 |
They are only 23.1x34
jeremy ![]() Bronze Level ![]() Joined: 04 Aug 2015 Location: Clarkson, Ne Points: 29 |
Why everyone is talking fat tires does anybody know where I could find a set of 24.5x32 rims and centers? Im restoring a d21 that they would go on. Thanks.
Shawn PA ![]() Silver Level ![]() Joined: 20 Sep 2009 Location: Hickory PA Points: 164 |
I have a set on 9 bolt rims. But they are probably not what you'd want for a restored tractor.
My other question is what hubs are you using to bolt on your steel wheels
Post Reply ![]() |
Page 12> |
