WC Tires
NDBirdman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NDBirdman Quote  Post ReplyReply Direct Link To This Post Topic: WC Tires
    Posted: 21 Jan 2015 at 10:31pm
Tires on my WC are in severe need of change, mismatched/rotten.  I plan on attending a couple tractor pulls with it after I get the head gasket replaced.  I have found a good set of 11.2 X 26, is that a good size for all around use and some tractor pulls?  Tires are supposed to be stock size or one size bigger allowed.
1955allisca View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1955allisca Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jan 2015 at 6:04am
That's aweful small, a good WC will turn 16.9-26s no problem id say 13.6 26s would be better i run 14.9 and 16.9s on mine
Pipe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pipe Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jan 2015 at 7:42am
I am pretty sure that one size over would be 14.9 and wc came with 24,28 and 36.Might what to check the rules on Od. size before you get 26 inch tires. 13.6x28 might be the way to go depends on what kind of track you have clay or sand.
BennyLumpkin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BennyLumpkin Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jan 2015 at 10:15am
13.6x28 is a good size to pull with on a WC. That's what I ran until I went to 38's
Central PA Allis Express
1934 WC254
1945 WF
1945 WC135755
1951 WD68085
1953 WD45-150217
1957 WD45D-230744D
B110
Post Options Post Options   Thanks (0) Thanks(0)   Quote NDBirdman Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jan 2015 at 12:58pm
My bad, trying to think when I'm on meds from the freeking flu, spoked 24 inch rims is what is on her.
Quote
Most tracks I've seen around here are clay.  I want to stay with original rims, what size would you recommend?
Edited by NDBirdman - 22 Jan 2015 at 12:58pm
Pipe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pipe Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jan 2015 at 7:29pm
13.6 uncut and 14.9 for cut tires firestone 23 degree I have ran 13.9 x 38 and did well also but I have a step down trans also.
Good luck
Kip-Utah View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kip-Utah Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jan 2015 at 11:18pm
The 14.9 x 24 tires on our 37 & 38 WC pullers have worked fine for us on the stock rims. The 37 is on spokes and the 38 is pressed steel discs. Both of these style rims are fairly narrow 6 to 8 inches wide and conventional wisdom says this is a poor combination...our trophy shelf says otherwise!! Actually the tires on both tractors are intended for use on center pivot irrigation systems. The 37 has one Goodyear 45 degree and one Firestone 30 degree mismatched set and the 38 tires are 30 degree Chinese generic "Irrigation Special" tires.
Post Options Post Options   Thanks (0) Thanks(0)   Quote NDBirdman Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2015 at 12:44am
Mines a '36 unstyled.  Will the 14.9 x 24 fit under the fenders with no modifications?
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2015 at 4:53pm
Original size would have been 11.25 x24 old size, newer size 14.9x24 (13x24) newest size 380/85x24.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kip-Utah Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2015 at 11:37pm
14.9 X 24 tires fit fine with either style WC fender.
This page was generated in 0.285 seconds.
