D17 1 weight brackets
Allis Nation View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis Nation Quote  Post ReplyReply Direct Link To This Post Topic: D17 1 weight brackets
    Posted: 13 Jan 2015 at 9:31pm
Anyone have any good pictures of how they mounted their rear weight brackets on a d17? I have an idea how i want to do them but i figured it wouldn't hurt to get more ideas first.
Charlie175 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jan 2015 at 5:48am
I'm currently redoing mine. I am making a plate to bolt to the four cradle bolts with a braced 36" long x 5" plate for the weights to hang.
I still have my PTO and SC stuff though.
If you remove the PTO/Lift arm housing and made a cover plate, I have seen others with this setup so that the weights are much higher.
Charlie
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jan 2015 at 5:50am
This is how Gary had his setup
Charlie
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis Nation Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jan 2015 at 12:30pm
Thanks for the replies, im hoping to keep them in front of the rear axle, the sled we pull weighs 36,000 pounds dry and pulls hard so im hoping to keep as much weight toward the front as possible. Last year i ran my buddies dc-3 and i couldnt keep enough weight up front even on the loose packed tracks. My thought was to mount the front of the brackets into the frame rails and find a place out back to tie the rear into with a bar running crossways under where the belt pulley is at.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jan 2015 at 1:37pm
Not much to hook to down there.
I have a frame mount that I can get 3 suitcase on per side which is 480 lbs. The rest goes up front for those real tight tracks.
Charlie
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jan 2015 at 1:39pm
Same tractor as above, you could extend the bracket back further.
Charlie
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis Nation Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jan 2015 at 3:16pm
Yeah thats kind of what im going after but back further and then a separate bracket out front
pohlman249 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote pohlman249 Quote  Post ReplyReply Direct Link To This Post Posted: 04 Feb 2015 at 4:16am
For front bracket I'm using a cultivator front bracket on my d17 with a pin on bracket to slide in..
Shawn PA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Shawn PA Quote  Post ReplyReply Direct Link To This Post Posted: 05 Feb 2015 at 6:29am
this is my belly bracket on a 17
Post Options Post Options   Thanks (0) Thanks(0)   Quote Shawn PA Quote  Post ReplyReply Direct Link To This Post Posted: 05 Feb 2015 at 6:30am
this is the rear  weight bracket and hitch are not together
This page was generated in 0.077 seconds.
