another 8010 question(s)
clint View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote clint Quote  Post ReplyReply Direct Link To This Post Topic: another 8010 question(s)
    Posted: 25 Mar 2010 at 8:28am
with the big ends in on the arms- it is too wide to fit my jd 2600 plow- it this normal? the plow is set for cat 2 or cat 3, and i want it hooked cat 3. the best i can get is 1 big end one small- it has play.
also the tb doesnt work- the cable is free- which of those 3 holes should the linkage be in? mine is in the middle. zero response.
last night i wanted to turn the tractor off to check something- i turned off the key, but got out of the cab without shutting off the fuel. ran for several minutes like that before i got back in saw the tach etc off- did i hurt anything?
Our farms stuff: agco gt55, AA 8775, 8765, 6080, 185, 180, 175, 170, d15, d14, d14, wd, wd, wd, g, F3, L3, R62
monitordoc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote monitordoc Quote  Post ReplyReply Direct Link To This Post Posted: 25 Mar 2010 at 9:16am
 YOU NEED A LITTLE SIDE TO SIDE FREE PLAY IN THE THREE POINT OR YOU WILL BEND OR BREAK SOMETHING.  AS FAR AS RUNNING WITH THE KEY  OFF-- I KNOW OF GUYS WHO RAN THAT WAY TO CUT BACK ON TACH HOURS FOR TRADE IN TIME. THEY WOULD TURN THE KEY ON TO CHARGE THE BATTERIES THEN OFF AGAIN.
WD,D17-S4,180,D21
BobHnwO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BobHnwO Quote  Post ReplyReply Direct Link To This Post Posted: 25 Mar 2010 at 9:37am
I addressed the sway blocks at the end of your other post,sway blocks should have the small end in,with the plow hooked up the distance between the 3 point arms should be about 32 inches on the inside.
Post Options Post Options   Thanks (0) Thanks(0)   Quote BobHnwO Quote  Post ReplyReply Direct Link To This Post Posted: 25 Mar 2010 at 9:46am
With the position control lever all the way forward you should be able to raise and lower the 3 point arms with the traction control lever,if not check fluid level.
Post Options Post Options   Thanks (0) Thanks(0)   Quote clint Quote  Post ReplyReply Direct Link To This Post Posted: 25 Mar 2010 at 11:48am
should i use the diff lock?
Post Options Post Options   Thanks (0) Thanks(0)   Quote BobHnwO Quote  Post ReplyReply Direct Link To This Post Posted: 25 Mar 2010 at 12:08pm
not unless you get stuck.
