air filter placement |
alan-nj
Joined: 12 Sep 2009 Location: oxford, nj Points: 847 |
Topic: air filter placementPosted: 07 Jan 2015 at 9:44am |
i'm intending to change the oil bath filter on my wc to a dry k&n mounted behind the 464 body carb.......any pros and cons to mounting directly at carb, or use a piece of pipe (what length?) between carb and filter.......
blue924.9
Joined: 22 Mar 2013 Location: George Iowa Points: 1089 |
Posted: 07 Jan 2015 at 10:37am |
NOOOOOOOOOOOOOOOOOOOOOOOOOOOO!!!!!!!!!!!!!!!!!!!!!!! dont use a k&n, they have a known history for letting air that is unfiltered and pure dust get past them.
hi my names dan, I am a young guy. i have a problem, i prefer my tractors orange and my clutches mechanical, thanks for letting me share
cwhit
Joined: 12 Sep 2009 Location: Sigel IL Points: 1014 |
Posted: 07 Jan 2015 at 6:33pm |
Alan, you want to mount the filter where it will recieve the coolest air posible. |
DrAllis
Posted: 07 Jan 2015 at 7:45pm |
Above the hood is best, but if you use a metal tube that is bent by a tailpipe bender with a pinched corner.......I don't know how good that is. Smooth mandrel bent piping as larger or larger diameter than the carb inlet is best. K&N filters are fine when oiled properly.
