To Prime or Not To Prime?
DennisA (IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DennisA (IL) Quote  Post ReplyReply Direct Link To This Post Topic: To Prime or Not To Prime?
    Posted: 26 Nov 2010 at 5:32pm
 I remade a hopper for a potato planter out of stainless. I am getting ready to paint and was wondering if I need to prime it first. What do you recommend?
Thanks & God Bless
Dennis
427435 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 427435 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Nov 2010 at 5:37pm
A major thing when painting is paint adhesion.  Besides having the metal clean (especially of any oil), a good primer is a big help.
Mark
B10 Allis, 917 Allis, 7116 Simplicity, 7790 Simplicity Diesel,
GTH-L Simplicity
Ignorance is curable-----stupidity is not.
panelbeater View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote panelbeater Quote  Post ReplyReply Direct Link To This Post Posted: 26 Nov 2010 at 5:38pm
it needs to be primed, i would use a self etching primer.
http://s2.photobucket.com/albums/y45/panelbeater/
Stan R View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan R Quote  Post ReplyReply Direct Link To This Post Posted: 26 Nov 2010 at 5:54pm
Stainless does not need any rust protection. You could leave it as is.
MNLonnie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNLonnie Quote  Post ReplyReply Direct Link To This Post Posted: 26 Nov 2010 at 6:09pm
I'd have to agree with Stan, when you said stainless the first thing I thought was why paint it?
Rayhowling View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rayhowling Quote  Post ReplyReply Direct Link To This Post Posted: 26 Nov 2010 at 8:51pm
Some metal parts and some equipment I have welded and built, I take a torch and heat the metal up and you would be surprised how mush moisture is in metal. I have heated 1/4 to 1/2 inch metal flat steel and the water will bead and run off of the steel even if it has been sitting in the sunshine for a couple of days. The paint sticks to the metal and it does not rust near as quickly when heated before painting.
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Nov 2010 at 8:56pm
I don't think paint (or primer for that matter) sticks to stainless all that well anyway.  I would leave it as is.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 26 Nov 2010 at 10:42pm
If you really want paint to stick to your stainless, I'd sand blast it so it has a satin finish. Roughing it up gives the paint something to hang on to.
Toscani SD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Toscani SD Quote  Post ReplyReply Direct Link To This Post Posted: 27 Nov 2010 at 7:04am
if u dont rough it up a little and prime,it will fall off period.
Unit3 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Unit3 Quote  Post ReplyReply Direct Link To This Post Posted: 27 Nov 2010 at 7:19am
Or buff until she shines like chrome.
Dusty MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dusty MI Quote  Post ReplyReply Direct Link To This Post Posted: 27 Nov 2010 at 8:57am
That moisture you are seeing may not be coming from the steel but from your torch, most gases contain moisture, especially natural gas and LP gas.
Dusty
BrettPhillips View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BrettPhillips Quote  Post ReplyReply Direct Link To This Post Posted: 27 Nov 2010 at 9:22am
Toscani's got it right.  If you must paint it, sandblast and then use an adhesion promoting primer (like XIM's Flash Bond http://www.ximbonder.com/products_detail.asp?id=63 )  I had an awful time getting paint to stick to a stainless project at my day job, and this was the only thing that worked in the end.
David Maddux View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote David Maddux Quote  Post ReplyReply Direct Link To This Post Posted: 27 Nov 2010 at 9:45pm
We used to use the xim flash bond for hard to hold areas, works like a charm. Just not as cheap as other stuff.
