To Prime or Not To Prime? |
DennisA (IL) ![]() Orange Level ![]() Joined: 11 Sep 2009 Location: Ridott IL. Points: 2064 |
![]() ![]() ![]() ![]() ![]() Posted: 26 Nov 2010 at 5:32pm |
I remade a hopper for a potato planter out of stainless. I am getting ready to paint and was wondering if I need to prime it first. What do you recommend?
Thanks & God Bless
Dennis |
427435 ![]() Orange Level ![]() Joined: 18 Nov 2010 Location: SE Minnesota Points: 18637 |
A major thing when painting is paint adhesion. Besides having the metal clean (especially of any oil), a good primer is a big help.
Mark
B10 Allis, 917 Allis, 7116 Simplicity, 7790 Simplicity Diesel, GTH-L Simplicity Ignorance is curable-----stupidity is not. |
panelbeater ![]() Bronze Level ![]() Joined: 05 Oct 2010 Location: kingston nh Points: 22 |
it needs to be primed, i would use a self etching primer.
http://s2.photobucket.com/albums/y45/panelbeater/
Stan R ![]() Orange Level Access ![]() Joined: 03 Dec 2009 Location: MA Points: 992 |
Stainless does not need any rust protection. You could leave it as is.
MNLonnie ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Baxter MN Points: 4791 |
I'd have to agree with Stan, when you said stainless the first thing I thought was why paint it?
Rayhowling ![]() Silver Level ![]() ![]() Joined: 02 Jan 2010 Location: Ont. Points: 178 |
Some metal parts and some equipment I have welded and built, I take a torch and heat the metal up and you would be surprised how mush moisture is in metal. I have heated 1/4 to 1/2 inch metal flat steel and the water will bead and run off of the steel even if it has been sitting in the sunshine for a couple of days. The paint sticks to the metal and it does not rust near as quickly when heated before painting.
DSeries4 ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: Ontario, Canada Points: 7495 |
I don't think paint (or primer for that matter) sticks to stainless all that well anyway. I would leave it as is.
If you really want paint to stick to your stainless, I'd sand blast it so it has a satin finish. Roughing it up gives the paint something to hang on to.
Toscani SD ![]() Bronze Level ![]() Joined: 28 Dec 2009 Location: South Dakota Points: 42 |
if u dont rough it up a little and prime,it will fall off period.
Unit3 ![]() Orange Level ![]() ![]() Joined: 17 Oct 2009 Location: NC Iowa Points: 5595 |
Or buff until she shines like chrome.
Dusty MI ![]() Orange Level ![]() ![]() Joined: 13 Sep 2009 Location: Charlotte, Mi Points: 5059 |
That moisture you are seeing may not be coming from the steel but from your torch, most gases contain moisture, especially natural gas and LP gas. Dusty
BrettPhillips ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Strasburg, VA Points: 808 |
Toscani's got it right. If you must paint it, sandblast and then use an adhesion promoting primer (like XIM's Flash Bond http://www.ximbonder.com/products_detail.asp?id=63 ) I had an awful time getting paint to stick to a stainless project at my day job, and this was the only thing that worked in the end.
David Maddux ![]() Orange Level ![]() Joined: 13 Sep 2009 Points: 2535 |
We used to use the xim flash bond for hard to hold areas, works like a charm. Just not as cheap as other stuff.
