Tire & Rim Question
Zyta View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Zyta Quote  Post ReplyReply Direct Link To This Post Topic: Tire & Rim Question
    Posted: 25 Mar 2011 at 9:20pm
I have a pair of 15'' power adjust rims are they to big/wide for a 14.9-28 tire?
Jim
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 25 Mar 2011 at 9:41pm
Yes.  I have 18.4s on 15" rims.
Calvin Schmidt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2011 at 5:50am
We could do some trading.
Dick L View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2011 at 6:01am
All depends on how your going to use the tractor. If you are not showing it with the wider rims you love them in the field. If you want to go to pulls you will also love them unless someone gets out a ruller and gives you a DQ.
Lester View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lester Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2011 at 6:03am
They will work fine. We always like to use extra wide rims for better traction and flotation. Most tractor pullers rims  are extra wide too. 18.4 calls for 16'' rims not 15'', although one can get by with that.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2011 at 10:26am
my mistake, I didn't look too close at my measuring tape.  I just don't know how a rim can accept a tire that is narrower.
Tony.Or View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tony.Or Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2011 at 1:41pm
 14.9  tire  needs  a  13 "  rim to set  correct and pull best .   Tony
Zyta View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Zyta Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2011 at 9:10pm
I have heard guy's talking about 16.9's on the 45's versus 14.9's. My 15'' rim would be perfect for 16.9's.
Now that the Firestone Field and Road is gone haven't found a Bias ply tire that looks good.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 27 Mar 2011 at 12:41am
Field and road is gone???  I just had 6 new ones installed last week.  I had to wait for one of the tires to get made - tag on that tire said March 11.  Got 2 18.4 x28 for the 175, and 14.9 x 26 for both the 59 D14 and D15 II.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 27 Mar 2011 at 12:51am
On the second picture, you may notice that the tire on the 175 in the background is flat.  The guy that installed them forgot to tighten the valve stem on that one!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 27 Mar 2011 at 6:51am
Just had 6 installed? Yeowch! 2 were more than enough for me 3 years back...
