Tire chain measurements |
littlemarv ![]() Orange Level ![]() Joined: 10 Jun 2013 Location: Wisconsin Points: 1834 |
![]() ![]() ![]() ![]() ![]() Posted: 16 Oct 2022 at 5:50pm |
Anyone know what size chains fit a 13.6 by 28 tire? I see a lot of ads where they only have the measurements of the chains, for instance "set of chains, measures 18" by 10 feet".
Thanks in advance. |
The mechanic always wins.
B91131, WC23065, WD89101, CA29479, B1, Early B10, HB212, 416H |
AaronSEIA ![]() Orange Level ![]() Joined: 11 Sep 2009 Location: Mt Pleasant, IA Points: 2569 |
I'm pretty sure I told you on Facebook, but I'll say it here for anyone else. Look up the Laclede Chain web site. They are the only place I've found to give dimensions for their chains. AaronSEIA
truckerfarmer ![]() Orange Level Access ![]() ![]() Joined: 26 Jan 2013 Location: Watertown, SD Points: 3280 |
Measure the diameter of your tire and multiply by 3.14. That will give you the circumference (length around the tire). As long as they are wider than the tire, they should drop down the sidewall, thusly shortening the length needed to connect the ends.
'53 WD, '53 WD45, WD snap coupler field cultivator, #53 plow,'53 HD5B dozer Duct tape.... Can't fix stupidity. But will muffle the sound of it! |
steve(ill) ![]() Orange Level Access ![]() ![]() Joined: 11 Sep 2009 Location: illinois Points: 87440 |
as trucker said, your tire should be about 52 inches in diameter, so the circumference is 52 x 3.14 .... or 163 inches around , which is 13.6 ft.
If your chains are 18 inches wide so that they drop 3 inches down on the sidewall on each side, then the tire diameter would be 52 - 6 or 46 inches..... that would be 46 x 3.14 or 144 inches long , which is 12 ft long chain. Edited by steve(ill) - 17 Oct 2022 at 8:16am |
