Tightening the power steering belt on a 160
farmtechguy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote farmtechguy Quote  Post ReplyReply Direct Link To This Post Topic: Tightening the power steering belt on a 160
    Posted: 19 Jan 2026 at 4:50pm
My 160 has very weak power steering. I think I tracked down the likely cause being belt is quite loose. I didn't think to check it while it was cold and it's a lot looser then I realized.
Thank you AC720Man for suggesting that.
The service manual shows 4 bolts. Two look like they're tucked in the frame rail. I can see why people are saying it's a pain to adjust.
Any tips or tricks for tightening?
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 21 hours 45 minutes ago at 8:44pm
Will have to look at my 160 tomorrow, kinda forgot how I adjusted mine. I installed a new belt and adjusted. It has to be the exact length belt as there isn’t much adjustment on it. I do remember that. Seams like I used a slight angled pry bar to hold the tension while I tightened the bolts.
Edited by AC720Man - 21 hours 43 minutes ago at 8:46pm
