Throttle ajustment
Pipe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pipe Quote  Post ReplyReply Direct Link To This Post Topic: Throttle ajustment
    Posted: 18 Mar 2011 at 11:40am
Needing a little help . On a allis B with a mag I have no ajustment for the throttle. one notch is wide open the next idling.It has  the spring and the weight on the governor and the throttle rods seams to be ajusted right . Figure I need to get inside and look at the Governor. Wanted to ask for ideas here first .
sandylakeimplement View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote sandylakeimplement Quote  Post ReplyReply Direct Link To This Post Posted: 18 Mar 2011 at 12:20pm
The gov is the place to look. The external governor spring tries to pull the carb in the wide open direction and the internal centrifugal weights try to take the carb back to idle. They work together to balance out but it sounds like your weights aren't doing there thing!  Bill
Sandy Lake Implement
Sandy Lake, PA
724-376-2489
www.sandylakeimp.com
FIND US ON FACEBOOK
