three point conversion ? |
TomYaz ![]() Orange Level ![]() ![]() Joined: 14 Sep 2009 Location: PA Points: 10325 |
![]() ![]() ![]() ![]() ![]() Posted: 24 Apr 2011 at 10:13am |
Got a cross three point conversion for my wd45...
Question on the top link bracket....its nothing more than a u-shape with a couple bolt holes. One set of holes for the arm, the other to keep the bracket on the tractor lift shaft..
But what is to keep this bracket from sliding all over the tractor lift shaft???
BobHnwO ![]() Orange Level ![]() ![]() Joined: 16 Sep 2009 Location: Jenera Ohio Points: 693 |
nuthin!
DaveKamp ![]() Orange Level Access ![]() ![]() Joined: 12 Apr 2010 Location: LeClaire, Ia Points: 5891 |
Like Bob said... it's just clamped on. Really, since the top link can swing every-which-way, there's not enough side-load to make it take a walk.
Brian G. NY ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: 12194 Points: 2245 |
I simply put two muffler clamps on either side of my homemade top lnk bracket to keep it centered.
steve(ill) ![]() Orange Level Access ![]() ![]() Joined: 11 Sep 2009 Location: illinois Points: 83949 |
in reality the rock shaft rotates, but the bracket dont. It always points directly at the top link pin on the implement. Straight pull.
Dakota Dave ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: ND Points: 3962 |
I had to put a muffle clamp on each side of the bracket to keep it from sliding back and forth.
David Gibson (OH) ![]() Orange Level ![]() ![]() Joined: 30 Oct 2010 Location: Hollansburg, OH Points: 493 |
Mine is like Brian and Dave's. I have a muffler clamp on each side. |
Sounds like its not much to worry about...
Thanks Guys..
Tom
