thread locker on rod bolts????
tractorboy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tractorboy Quote  Post ReplyReply Direct Link To This Post Topic: thread locker on rod bolts????
    Posted: 28 Mar 2010 at 8:08pm
I asked at napa for the pal locking nuts, he had none. What do you guys use to make sure the rod bolts stay tight??    PS, I'll be putting the engine back in the B, and will use a 3/16 plate to give me clearance between the clutch shaft and the crankshaft. I know this is unheard of, but it's ouick and easy!  Keith
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 28 Mar 2010 at 8:15pm
Wire
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 28 Mar 2010 at 8:30pm
McMaster-Carr www.mcmaster.com has Palnuts.
http://www.mcmaster.com/#palnuts/=6f5rxg
Not expensive either, if they have the size you need, I hope 3/8" fine thread.
Gerald J.
This page was generated in 0.120 seconds.
