Tell me something,,,,, |
Page 12> |
desertjoe ![]() Orange Level Access ![]() ![]() Joined: 23 Sep 2013 Location: New mexico Points: 13729 |
![]() ![]() ![]() ![]() ![]() Posted: 28 Aug 2019 at 5:47am |
OK,,on the 1982 Silverado C10 I bought a couple of weeks ago,,,,Yes Shameless,,I bought a Chevy to stay in your good graces,,,,,
Thad in AR. ![]() Orange Level Access ![]() ![]() Joined: 12 Sep 2009 Location: Arkansas Points: 9668 |
Flat lobe on the cam. 305’s are well known for it.
jaybmiller ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Location: Greensville,Ont Points: 24763 |
probably the 1983 gas still in the tank..... OK,... did you replace ALL the fuel filters ? mileage reading ??
Edited by jaybmiller - 28 Aug 2019 at 6:09am |
truckerfarmer ![]() Orange Level Access ![]() ![]() Joined: 26 Jan 2013 Location: Watertown, SD Points: 3291 |
Have you checked the timing?
'53 WD, '53 WD45, WD snap coupler field cultivator, #53 plow,'53 HD5B dozer Duct tape.... Can't fix stupidity. But will muffle the sound of it! |
JoeM(GA) ![]() Orange Level ![]() Joined: 12 Sep 2009 Location: Cumming,GA Points: 4838 |
Agree with Thad, flat lobe, usually one of the back cylinders, wife’s Delta 88 did it too
Allis Express North Georgia
41 WC,48 UC Cane,7-G's, Ford 345C TLB |
Yeah, Trucker,,that was first thing I checked and timing was way fast as engine turned over some slow and perked right up after backing off the timing bout 6-8°,,now starts right up and revs up better but has that dang backfire to it. Aw,,CHIT,,,Thad,,I remember now bout you tellin me them 305's were notorious for bad camshaft lobes,,,chit, chit,,, Guess I better pull valve covers and see if I can spot which one(s) it is. I can also hear a loose lifter on driver side which may explain the bad lobe,,huh?? UMMmm,,,you gots a good 327 or 350 in your back pocket,,,,,
chaskaduo ![]() Orange Level ![]() Joined: 26 Nov 2016 Location: Twin Cities Points: 5200 |
Careful there Joe that could cause Shammers to faint and knock his hard head ruining his floor.
Stan IL&TN ![]() Orange Level ![]() Joined: 13 Sep 2009 Location: Elvis Land Points: 6730 |
Well for what it's worth. Dad's truck at the farm 1988 Chevy with the 4.3 V6. It don't get used much and for last 5 years it has ran terrible. Pulling out on the highway was dangerous as it would choke, backfire, hesitates, puke, caugh and if you were patient enough and feather the throttle you could get it up to speed in about a half mile. Anywho I had already changed the fuel filter 5 years ago when it started and ran several tanks of treated gas through it. Last summer I changed the cap, rotor, wires, plugs and ignition module and none of that helped. Took it to the shop and they called me and asked if it sat much of the time. Well yes. They changed the filters and added a can of Seafoam and said it was bad gas or water in the gas.
That's all I got but the darn truck runs like a top now. Still scratching my head. |
1957 WD45 dad's first AC
old farmer ![]() Silver Level Access ![]() ![]() Joined: 12 Oct 2011 Location: Sturgis, Mich Points: 341 |
We a 305 with bad cam. The repair shop use a cam from a different motor, but don’t know which it was.
PaulB ![]() Orange Level ![]() Joined: 12 Sep 2009 Location: Rocky Ridge Md Points: 5149 |
Shove-Or-LetSet???
Ray54 ![]() Orange Level Access ![]() Joined: 22 Nov 2009 Location: Paso Robles, Ca Points: 4759 |
![]() ![]() ![]() ![]() ![]() I ant no mehanic ![]() ![]() ![]() ![]() ![]() |
Well,,Guys,,,it lookin like I did NOT luck out on this Silverado as I pulled the driver side valve cover and 3 of the four exhaust rocker arms do not move at all,,,,CHIT, CHIT, CHIT,,!!! THats weird as I drove the trk up on the trailer and while it had a slight miss,,there was no indication THEN of the flat camshaft lobes. It's just getting worse the more the engine runs,,I guess,,,,I checked the oil level and is full on the dipstick. The trk has the oil pressure gauge instead fo the lights and even now is carrying 25# at idle and 50# when reved up,,,,Should I replace oil pump with these pressures?? Guess I need to start dis-assembling everything to pull the engine tomorrow and at the very least,, put a new camshaft and lifters in it. I've replaced camshafts in SBC's without pullin the engine but I'm gonna pull engine so I can clean and detail it really nice. Was there a design flaw with the metallurgy of the camshafts in the 305's or,,,???? OH,,one more for the Chevy people,,I can pick up a clean 350,,(I think mid to late 80's) for a good price but it is the throttle body type where mine is a carburator type. Could I put my intake manifold and distributor on the throttle body block,,,??????
First see if it has a fuel pump plate and bore? Some did some didn’t. The intake will have to be redrilled /egg shaped if I recall correct. A tbi carb manifold can be had fairly cheap if you prefer that. |
Center intake bolts go in straight up and down not square to mating surfaces on TBI heads
Chit,,Thad,,after re-reading my last post,,,even I can't really understand WTF I want to do,,,,,, ![]() ![]() Anyway, my 305 does have a block mounted fuel pump,,,,,,
Joe it’s really not that complicated and you could run carb heads on that TbI motor. The fuel pump would be the only deal breaker for me. Maybe half the TBI motors will accept a fuel pump. |
JC-WI ![]() Orange Level Access ![]() Joined: 11 Sep 2009 Location: wisconsin Points: 34369 |
Thad, can't he just mount an electric fuel pump on?
Yes a low pressure pump would work fine. I’m just not a fan.👍
![]() That cam can get real bad real fast. My dad and his best buddy liked going to the livestock auction a 100 miles away. Nether liked wrenches and all that grease and oil. They liked ![]() I know the rest of the world is not so regulated, ![]() ![]() Oh the friend down the road that does engine machine work also told me 7 psi in chevy was all you needed for oil pressure. Claimed race guys liked it low to not be wasting power they could use for other purposes.
shameless dude ![]() Orange Level ![]() ![]() Joined: 10 Apr 2017 Location: east NE Points: 13607 |
I had a great 327 that I had put in my dad's truck, then one of the stock holders sold the truck out from under me to the scrap yard. they had it crushed before I could retrieve it. he got the corp. $64. for the whole truck, rust free '67 Chevy …..PffffT!
That sum of a bich woulda been walkin bow legged if he got up off the ground...
They would probably recycle the Declaration of Independence if given the chance.
Dave H ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Central IL Points: 3591 |
like ray said, stick another cam in it and let her rip.
![]() Edited by Dave H - 30 Aug 2019 at 7:29am |
Hey Shameless,,,I gots bout a half case of ACV and TWO cases of Black LABEL I'll trade you for thet 327,,,Ten Four,,,,??? ![]() ![]() Yeah, Dave,,thas what i'm headed for,,I just bout got all the wires and things disconnected except for the torque convertor bolts and she's comin out,,, ![]() ![]() Something real puzzling tho,,,,,the exhaust manifolds are both like the ones on the 265's of 55 and 56 vintage. They are not the rams horn style like I figured they would be but the PO told me they bought the trk "almost" new in OKlahoma and engine has never been opened up,,,,only'ist thing they done was a new starter and quadrajet carb. I tend to believe him as all the bolts have been super tight,,chit,,,I like to never got the bolts on the A/C compressor broke loose,,had to get a 1/2" drive breaker and a 3 foot cheater on 3 of them,,!! No problem on the manifolds as I already gots a set of Hookers to take their place along with a couple of 36" glass packs,,,,,yippie yay,,,,,It gonna sound so good,,,I be thinkin I'm back in the 50's like one of them youngsters,,,,
I have a tube of cam break in lube and some zddp I can mail you if you go the cam route. The new oil won’t have nuff zddp for flat tapper cam break in. Let me know.
Dang,,Thad,,I had not heard that word in a LONG time,,!! We used to add a small bottle of the break- in oil that was primarily ZDDP in every engine we built that was gonna see severe duty,,as in "leadfoot use",,,, ![]() ![]() I plumb got out of tearing them engines up that we spent so much money on building them up,,,, ![]() ![]() I haven't done a complete rebuild in a long time,,fact is,, I think the 406 in ole Red IS the last one I done. I think I still have bout half a tube of Lubriplate in the cabinet that was the last thing that went on the bearings before lashing up the engine,,,,The only'ist thing good bout them "good ole days" is they is maybe gone forever,,, sigh, sigh,,, So far,,I've had 3-4 others tell me bout the inherant problem with the 305 engines. was it a metallurgy problem with the camshafts or was it an oiling problem I need to watch for if I rebuild this engine?????
I can’t honestly answer your question but I never heard of it happening with an aftermarket cam.
I had to replace a cam in an '82 Malibu once, musta been a weak cam in that era. took a couple hours...no big deal.
Your funny Shammers, that was then this is now. I'm sure DJ remembers those days too. It would take me a couple months now, how bout you? Poke Poke
well,,you see,,Chask,,,,I do not argue with thet man,,,for chit,!! He gots way too many ways to get back at you ,,,,chit,,the last time I questioned something he said,,,I got pulled over 3 times goin to the Alien town,,then twice comin back,,,!!!! ![]() ![]() Every one of them coppers,,,er,,,I mean "Officers" told me to be careful of what I was doing and not a one would tell me what I was being pulled over for,,,,,,,one of the state troopers stuck his head in the window and whispered,,,,,"You ever been to Nebraska?" I KNEW IT THEN,,!! So,,you see now,Chask,??
Page 12> |
