tac and hour meter ?
Daehler View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Daehler Quote  Post ReplyReply Direct Link To This Post Topic: tac and hour meter ?
    Posted: 14 Jun 2015 at 10:50pm
Working on tracing problem on why my tac and hour meter isn't working on a 8000 series. They have kicked on separately from each other in the pass but dont know much for a starting point.
8070FWA,7080 BlackBelly, 7045,2 200s,D19,D17,G, WD,45,UC,7 AC mowers and lots more!
"IT TAKES 3 JD's TO OUT DO AN ALLIS, 2 TO MATCH IT IN THE FIELD AND 1 FOR PARTS!"
Leon B MO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Leon B MO Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jun 2015 at 5:54am
Check the flywheel sensor, on ours the sensor backed out of the mounting base. It works now.
Leon B
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jun 2015 at 6:03am
bad grounds ?  could be vibration over the years has broken the wires( won't look bad).
just things I've seen before....sigh
Jay
Post Options Post Options   Thanks (0) Thanks(0)   Quote Daehler Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jun 2015 at 9:44pm
Were would the all the grounds be checked? Checked the sender on flywheel and a wire was broken did a do it your self fix and nothing from it. It looks like it rubbed at one point.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Daehler Quote  Post ReplyReply Direct Link To This Post Posted: 27 Mar 2016 at 3:19pm
Bump. Still haven't found problem. There is power that comes up to the meter but nothing is coming off the other two brown wires that go to the sensors. Have no juice at the flywheel sensor. Is it in the meter itself?
Lynn Marshall View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lynn Marshall Quote  Post ReplyReply Direct Link To This Post Posted: 27 Mar 2016 at 7:26pm
There's no voltage (juice) going to the sensor. The sensor creates a magnetic impulse signal to the meter as the flywheel passes by it. The sensor has a specific ohms reading if checked with an ohm meter. I don't presently know that amount. You could check the ohms reading against a new or good used one if available.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Daehler Quote  Post ReplyReply Direct Link To This Post Posted: 29 May 2016 at 11:40am
Still working on getting this tach going. Bought a new sensor and still nothing. Going to check with ohms meter at sensor but could the tach and hour meter just be bad? Or is the flywheel supposed to be in a certain spot.
Dustyn mccloud View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dustyn mccloud Quote  Post ReplyReply Direct Link To This Post Posted: 11 Nov 2016 at 6:28pm
D17 allis chalmers series 3 with loader mid conditio gas what u guys think on price wants 4000
