suggestions on starter rebuild on CA starter?
steve View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve Quote  Post ReplyReply Direct Link To This Post Topic: suggestions on starter rebuild on CA starter?
    Posted: 04 Oct 2023 at 6:49pm
I need suggestions on getting  a 70 yr old starter for a CA rebuilt. Would NAPA even touch an old Delco? SEMO. thanks
51 CA, 57 CA, 53 CA(in progress)
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 04 Oct 2023 at 6:59pm
contact Steve@B&B, since you're south of the 49th !!
Big question is it a REAL 12 volt starter ,or actually a 6 volt unit ? Tag number will tell.
After Steve, call around for a rebuilder as NAPA are just  a 'counter'.
A proper rebuild will have all new bearings, brushes, etc.
My CA ( '51?? ) , I just needed to rebuild the push starter guts.
dfwallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dfwallis Quote  Post ReplyReply Direct Link To This Post Posted: 04 Oct 2023 at 7:02pm
I just had mine rebuilt by Fort Worth Starter and Generator (and the generator).  They had no issues or difficulties getting parts or doing the work.  The labor was around $86.  The generator ran around $350 total.  I had planned on rewinding the generator, but he elected to get new parts instead.  The starter only needed some minor cleaning and bearing work.
Edited by dfwallis - 04 Oct 2023 at 7:36pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 04 Oct 2023 at 7:12pm
If you want to call STEVE.. im sure he can help, or lead you in the right direction..
-----from another post--------
 I offer a nice wiring system as well. Give me a call .... Our website is temporarily down due to a domain change and the site is getting moved over.
Steve@B&B
(973) 632-5596
DSpears N IL View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSpears N IL Quote  Post ReplyReply Direct Link To This Post Posted: 04 Oct 2023 at 7:50pm
I had my 6 volt delco starter for my CA push button switch and contact button replaced by a local repair shop for $45 last summer!
DeWayne
Post Options Post Options   Thanks (0) Thanks(0)   Quote dfwallis Quote  Post ReplyReply Direct Link To This Post Posted: 04 Oct 2023 at 8:13pm
DeWayne
I did that myself before I sent it off for rebuild.  I also partly cleaned it up beforehand to reduce the work some.
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 05 Oct 2023 at 3:57pm
Do a google search for "starter and alternator repair" in your town.  There are still small shops that do that.  It's where I take all of my starters and generators.
