Sub-Soiler
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Topic: Sub-Soiler
    Posted: 25 Feb 2025 at 10:40pm
Does anyone have any pictures of one?  I am looking for how it hooks up to the lift latches.
I just bought one that was on a D-14 and am going to use it on my WD45 and it only has a rod that is bent at the end and there are holes for a K-key or cotter pin.  I have no idea.
Can I modify it so it will fit a WD45?  Or should I trade it for one that fits the 45?
It is an Curved Shank Oxnard Model.
Thanks
Edited by Ted J - 26 Feb 2025 at 1:28am
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 26 Feb 2025 at 4:04am
there are several kinds, I think the wd's used a drawbar mount, you bolt the drawbar to the subsoiler, and use the DB to connect to the snap coupler, IIRR.  the one for my d-14 that I have experience with is a straight shank SC model...  Some pictures would help...Wink
truckerfarmer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote truckerfarmer Quote  Post ReplyReply Direct Link To This Post Posted: 26 Feb 2025 at 5:52am
Could be an older model that had the "box" that slipped over the lift arms and pinned on, and the "boxes" are missing. Is it just a rod with a loop on the end?
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 26 Feb 2025 at 6:33am
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 26 Feb 2025 at 6:34am
oopsy, kinda big.....
Is this like yours ?
sadly gave mine away 4 years ago when I 'lost' my storage shed.....(grrrrrrr)
Gary Burnett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 26 Feb 2025 at 7:26am
You may need to remove the PTO shaft on the WD,depends on the model of the subsoiler
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 26 Feb 2025 at 7:52am
gee Gary did you really mean 'drawbar' ?
 I know, you're having a 'senior's moment' or wishing it's only 22 days until SPRING
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 26 Feb 2025 at 8:07am
Go ahead and put one of those straight tongue SS on a WD and then you can go buy another PTO shaft.Have you ever even owned a WD much less know anything about it?
Yea I'm having a Senior Moment,its called experience.
IBWD MIke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 26 Feb 2025 at 8:32am
I believe the image Jay has posted is the exact model Ted is inquiring about. Oxnard, different from the others built in Athens. The 'bible' shows a different variant of the Oxnard model but pretty sure I've seen this style in the 'Oxnard deep tillage tools' book. It's out in the shop or I would have a look there. Will report back later.
Edit; Good to see you're still with us Ted!
Edited by IBWD MIke - 26 Feb 2025 at 8:32am
ac160 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac160 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Feb 2025 at 11:02am
I have a slightly different one than what Jay posted.  It uses the drawbar and the hands have to be removed and has "gloves" if you will that go over the lift  arms.
Kenny L. View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote Kenny L. Quote  Post ReplyReply Direct Link To This Post Posted: 26 Feb 2025 at 11:13am
 No Jay Gary is right they can bend the PTO shaft.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 26 Feb 2025 at 11:26am
wow... mine never got THAT close......
I suppose maybe different 'geometry' between WD and the D-14 ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 26 Feb 2025 at 11:42am
The pic that Jay posted is the correct one!  THANKS Jay!!
Now, the question is: where can I get those two pieces?  The ones that are on the ends of the lift arms that go into the lift arm latches.
Any body have them?
Thanks guys!  You come through AGAIN!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kenny L. Quote  Post ReplyReply Direct Link To This Post Posted: 26 Feb 2025 at 3:19pm
Ted give Bill Deppe a call 563-357-2615 he may or may not have them.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 26 Feb 2025 at 3:21pm
If it were mine, I would hook the eye to the coupler, and very gently lift the back end up, and see whether the geometry is right, if it comes close to the PTO, trade it off.  Gary is right if you bend up the PTO, its no bargain, trade it off...Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2025 at 9:03am
PTO shafts on WD's/45's are easily removable to accommodate mounted implements. Neither of my 45's have a shaft in them except on rare occasions. Like hooking to a dyno or something important like that.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2025 at 9:27am
Anybody have parts book for that style subsoiler.
tadams(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tadams(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2025 at 1:53pm
I have a2 bottom roll-over plow and have bent my PTO with it
jvin248 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jvin248 Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2025 at 7:44pm
(now Googling how to remove and return PTO on my WD).
Edited by jvin248 - 27 Feb 2025 at 7:44pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2025 at 8:58am
It's really not hard; Remove the two bolts in the carrier under the platform and the one in the dropbox shaft. Probably the hardest part will be prying it off the dropbox. If the tractor has ever ran a bush hog it will likely be mushroomed enough to not come off easily. This is why I quit bush hogging with my 45's and now use something else.
I put bolts (shorter) back in the holes for the bearing carrier. Seems like they drip a bit if you don't.
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2025 at 9:12am
Edited by PaulB - 02 Mar 2025 at 1:54pm
Dave (Mid-MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave (Mid-MI) Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2025 at 6:09pm
The earlier pin hitch models of this subsoiler had straight bars from front to back, and would bend a PTO shaft if not removed. The curved bars like in the pictured unit  would clear the PTO. I have a parts catalog from 1958 covering subsoilers, loaders, and cranes.
This page was generated in 0.045 seconds.
