Stuck TB spool, Any ideas? |
Reindeer ![]() Orange Level ![]() ![]() Joined: 14 Sep 2009 Location: Calgary, AB Points: 650 |
![]() ![]() ![]() ![]() ![]() Posted: 25 Jul 2010 at 10:10pm |
I just had my 170 painted, and although to the painter's credit, they were very thorough, they did get some paint on the end of traction booster spool. While out mowing I must have tripped the traction booster, because the spool went into the housing and won't come out. The 3 pt arms are all the way up, and staying there!
I,ve tried getting pliers to pull on the spool but it seems to be jammed solid. Any suggestions?
For reference, another post showing the same parts is:
This time the TB arm is nice and loose, but the spool itself is stuck. Sure looks nice, but it doesn't work!
I am thinking of taking the cap and spring off the back of the spool, and using a punch and hammer to get the spool back out where I can try to remove the paint. Any words of wisdom on that?
Skyhighballoon(MO) ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Pilot Grove, MO Points: 3115 |
Exactly what I suggest in my reply to your first post. Good luck! Mike
1968 Gleaner EIII w 10' & 330 1969 180 gas 1965 D17 S-IV gas 1963 D17 S-III gas 1956 WD45 gas NF PS 1956 All-Crop 66 Big Bin 303 wire baler, 716H, 712H mowers |
