Structures 1964 Allis D15 Series II |
Page <1 23456 12> |
michaelwis ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: Wi Points: 8765 |
Being the proud owner of D15 series 2 my DAD purchased new , I agree with all the above , ours has 6000 plus hours , but has never left the farm
Priceless, now if I could find our 190 XT, and 7040....... |
WD WD45 DIESEL D 14 D-15 SERIES 2 190XT TERRA TIGER ac allcrop 60 GLEANER F 6060 7040.and attachments for all Proud to be an active farmer
structures ![]() Silver Level ![]() ![]() Joined: 28 Feb 2011 Location: Beggs, OK Points: 335 |
Thanks guys appreciate it.
Chris the process is zinc. I bought most of the stuff from Caswell Inc. I did have to buy other stuff (like heaters, rectifier). I thought it was worth it to me as I have a lot of old hardware I want to restore.
Robert
1964 D15 Series II |
wfmurray ![]() Orange Level ![]() Joined: 13 Sep 2009 Location: Bostic NC Points: 1225 |
Got my dads D/14 and don,t see but one reason to not restore it is that you cannot afford it. Then sell to some one that wants to restore it and you can see it off and on.
Good morning. I'm getting closer to getting the 15 rolling again. May be a bit before it's under its own power though. ![]() These are 14.9-26 BKT TR-135 on the rear and 6.50-16 deestone on the front. Nothing fancy (well they were expensive though...). We'll see how they do.
My plan is to put the D15 to work. I had been looking to get a tractor and my dad offered this one up so I jumped on it. I just figured that I was going to put money into a newer tractor why not put that into something I already have. Plus I just enjoy fixing stuff.
Robert
Still trying out this zinc plating. I've been toying with parts that I plan on painting over mostly so they don't look the best, but the protection is there.
Robert
Got a little painting done this weekend.
Robert
Gary ![]() Orange Level Access ![]() Joined: 13 Sep 2009 Location: Peterborough,On Points: 5862 |
Oh no, not black !! Power Shift lock assm. should be all Cream. See attached Allis Brochure. Gary http://www.ebay.ca/itm/original-ALLIS-CHALMERS-D15-D-15-Tractor-sales-Brochure-Catalog-24-pages-/361173245765?pt=LH_DefaultDomain_0&hash=item54179a5f45 |
That's primer bud. See 2nd pic for cream. By the way I have that brochure. Refer to it all the time. Thanks!
Edited by structures - 30 Mar 2015 at 8:45am |
Robert
Kansas99 ![]() Orange Level Access ![]() Joined: 26 Feb 2015 Location: W Kansas Points: 4867 |
Looking good.
aras ![]() Orange Level ![]() Joined: 28 Jul 2011 Location: Weston, WI Points: 665 |
What do you think is the secret to a good plating finish? I assume the first pic is the parts after a plating attempt?
I'm still learning, but my first mistake was sandblasting these parts. It leaves a very matte finish. I should have followed up with a wire wheel treatment to smooth it out. The rest of the hardware I'm wiring brushing the rust off and last night I put half of it in the tumbler with some resin media and simple green. I'm eager to see how it turns out. If all goes well I'll try some walnut shells to smooth them out before plating.
Robert
Got some work done recently. Better get some pics posted. Plated a lot more hardware.
First tried the vibratory tumbler with simple green. That works pretty good. I run about 5 lbs of parts overnight ![]() ![]() I think the wire wheel works good too. But honestly with the heavily rusted parts they need to be blasted. However I did not blast any threaded hardware. ![]() ![]() Then I ran them in the tumbler with walnut shells overnight. Not for sure how much good that did. Actually I used fine shells and I'm thinking I needed a coarser grit. ![]() Then off to plating. First a bath in the degreaser. (The blocks I had to blast. They had some pretty heavy rust that the wire wheel could not cut through.) ![]() Then the plating bath ![]() Then dip in the blue chromate for 45 seconds ![]() Then hang and blow dry with a hair dryer. ![]() |
Robert
Also got the wheels on. New bearings/races and seals on the hubs and packed with grease.
![]() Got all the housings and pins installed. I didn't have any anti-sieze on me so I just used grease for the eccentric pin. ![]() To get the eccentrics on I worked the rim best I could to the wheel center and with the blocks in I slid the whole assembly on the rim rail. ![]() ![]() ![]() Must have got grease on the camera lens, but the 15 is on 4 rolling wheels now. Hopefully tomorrow I'll get her moved to the garage and start working on getting that engine free. ![]() |
Robert
Got the 15 moved from the farm over to my garage. Just barely cleared my 7' door.
![]() Took the valve cover off and the exhaust manifold to clean and inspect. ![]() Unfortunately as I was jolting the crankshaft around trying to get it to turn, a little rust hole popped open in the oil pan. It was a little pinhole until I put my finger through it. I was able to push a bigger hole into it. Looks like this engine is going on the stand! :) ![]() |
Robert
JimD ![]() Orange Level ![]() Joined: 11 Sep 2009 Location: Mounds, OK Points: 2112 |
I would put that engine on the stand and go over it very well anyway. You have been so detailed on everything up to this point, so logic in short cutting now. If you want to come over and drive a D15 II just to keep inspired, give a holler!
Owner of OKtractor.com PM for an instant response on parts. Open M-F 9-6 Central.
We have new and used parts. 877-378-6543 |
Haha. Thanks Jim. I'm sure I'll be seeing you shortly!
Robert
Just get it done before June 27th so you can have it in our town parade. I have to be out of town again, so I'll miss it. And I'm on the board of directors!
Bill Long ![]() Orange Level ![]() Joined: 12 Sep 2009 Location: Bel Air, MD Points: 4556 |
I fully agree with the "Father's Tractor" theory. I once touched the first flat top WC my father sold. Made me mad because it was painted BLUE. Thought about it and went back to buy it. Too Late.
I think of that every so often. Yes, you only have one Dad. Wish I could talk to him now. Good Luck! Bill Long ps: Let us know how it goes. |
Thanks Bill. Good Morning all. Got a little work done last night. Pulled the rocker arms and found a bent push rod. And pulled the head.
![]() Bent pushrod on the 2nd valve in from the forward end. ![]() Not for sure if this was a good idea to get the head off, but I did a little persuasive prying under the thermostat casting flange... Not too aggressive... ![]() ![]() Two cylinders were full of everything I've been dumping down the spark plug holes for a year. The other two were not. ![]() After I pumped the fluid out I wiped down the cylinders. This is what I'm looking at. Not the best picture. The cylinder walls have rust spots all over. ![]() |
Robert
The series II is my favorite tractor. I have 2, and 1 series I here. BUT, the 160 engine is a buggar to get parts for. They are out there, just priced well above the others. I spent a lot of time chasing Richland for sleeve source.
I do have OEM available on the sleaves.
Good to hear Jim. I'll be bugging you shortly I'm sure.
Last night was kind of a late one. I thought I could get this engine out pretty easily. I disconnected everything and slid the front mount plate as far forward as I could, but since the whole clutch assembly came out with the engine I put the crankshaft pulley in a bind and broke it... If only I had pulled the pulley... ![]() |
Robert
DSeries4 ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: Ontario, Canada Points: 7431 |
It's a lot easier to get the engine out by pulling the front axle and removing the frame rails. Fortunately, new crank pulleys are available aftermarket.
Here ya go.http://oktractor.com/zen/index.php?main_page=product_info&cPath=1_22_154_454&products_id=423 Edited by JimD - 16 Apr 2015 at 9:32am |
Yeah thanks. Lesson learned (again). Follow the shop manual! ![]() I'll be splitting the front when it goes back together.
Robert
Put the engine on the stand tonight, pressure washed it, and also pulled the pan. Pretty rough inside. While I was pressure washing the pan I blew some more holes into the oil pan.
Here's a look at the clutch and flywheel. ![]() ![]() Engine on the stand. ![]() Inside of oil pan. ![]() Inside the block ![]() ![]() |
Robert
Tracy Martin TN ![]() Orange Level Access ![]() Joined: 11 Sep 2009 Location: Gallatin,TN Points: 10691 |
Not as bad as I would have thought. Plug the holes on your power steering pump.Pretty sure that is the original ceramic type clutch disc. They were very thin to start with. Rick Corder in Mo.can fix you up with the properly set clutch and pressure plate. Turn the flywheel with the minimum cleanup as possible. If you do this , you will have a clutch that works properly and pedal will stand up correctly. The new clutch disc are too thick, this forces the pressure plate fingers to be too low, won't have enough spring pressure on clutch disc, and won't release properly. HTH Tracy
TimNearFortWorth ![]() Orange Level ![]() ![]() Joined: 12 Dec 2009 Points: 2014 |
Assuming those are a loader/blade mount on the side rails, you will def. want to be checking the "king pin" when you slide the front end out; that area can take a beating over time and get wallowed out.
Dave H ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Central IL Points: 3558 |
I sure hope it looks better than mine did. Fortunately my bushing was not wore all the way thru. |
VFDfireman ![]() Silver Level ![]() ![]() Joined: 11 Jan 2013 Location: South Dakota Points: 414 |
Fwiw I had a great deal of success cleaning my Wd45 block and crank that was in far worse condition by soaking the parts in a cow lick tub filled with a mix of purple power an water. I then removed the rust via electrolysis in a similar tub. |
Page <1 23456 12> |
