Sticking Clutch Pedal on a Allis Chalmers 8070 |
toasty_osty
Topic: Sticking Clutch Pedal on a Allis Chalmers 8070Posted: 05 Jan 2024 at 9:35am |
Hi, I own a 8070 that has recently been having problems with the clutch pedal sticking. I’m trying to figure if I can adjust I or if I need to replace anything. Thanks
8070nc
Joined: 21 Mar 2019 Location: North Carolina Points: 727 |
Posted: 05 Jan 2024 at 2:01pm |
Probably the cable
You could unhook it at each end alternately to determine if its in the cab or cable or valve |
1984 80780
1957 D14 DES 300 with 25000 engine 616 tractor |
Lynn Marshall
Joined: 13 Sep 2009 Location: Dana, Iowa Points: 2484 |
Posted: 05 Jan 2024 at 3:45pm |
If it's a power director tractor, it's probably the clutch cable.
Posted: 05 Jan 2024 at 5:45pm |
If the pedal doesn't come clear to the top by itself, it could also be the down-shift switch worn out or needing a shot oil oil on it.
Gregor
Joined: 11 Sep 2009 Location: Prague, Ne Points: 305 |
Posted: 09 Jan 2024 at 9:36am |
Replaced my 8070 Power shift clutch cable last year. Actually pretty easy job to do. I don't think it took me more than a half hour to change out. I did attach about 4 ft of weed eater string to old cable on the cab side. Pulled cable out from the valve side. Pulled in new cable with the string. Amazing how much easier the pedal moves now. I need to do my 8030 also. To troubleshoot, I unhooked on both ends and couldn't move the cable by hand or with a pliers.
