Starting a rebuild
jshoemaker View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jshoemaker Quote  Post ReplyReply Direct Link To This Post Topic: Starting a rebuild
    Posted: 08 Nov 2010 at 8:40am
I am done with my WC rebuild.  The engine is of course real tight and the starter is not spinning the unit very quick.  It is a 6 volt system, it will fire, run for a brief while, and die.  Should I just keep tinkering and it will eventually take off?  Will it become easier to start after it run for a while?  Thanks for any tips and help!
mlpankey View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 08 Nov 2010 at 9:36am
sound like its not either getting enough fuel or the coils acting up. on the fuel garvity eventually fills the carbs fuel bowl. but when the tractor is running and drawing more from the bowl than the restricted line is making up.
