starter?
mufflerboltz View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mufflerboltz Quote  Post ReplyReply Direct Link To This Post Topic: starter?
    Posted: 21 Feb 2014 at 10:47pm
What are you guys doing for starters on higher compression engines? Had an older gentleman tell me today that on these engines the nose cone can break.
patrickmull View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote patrickmull Quote  Post ReplyReply Direct Link To This Post Posted: 22 Feb 2014 at 10:39am
I have wonder this also i would like to put a gear reduction starter on mine
Edited by patrickmull - 22 Feb 2014 at 10:40am
cotncrzy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cotncrzy Quote  Post ReplyReply Direct Link To This Post Posted: 23 Feb 2014 at 6:56am
I have had starter night mares, but never broken a nose cone. I have sheared the drive off on several occasions. I have a starter guy that has built one heck of a starter, still a 6 volt, I use a 12V 1000cca battery, it will spin the heck out of mine, just cant take it for long.  I have 3 spares built carry one with the gas can wherever we go.
C, WD45,WD puller, 185, 200, 7060 Red Belly, 7060 Black Belly,8010, and a R52 Gleaner, AND PROUD OF THEM!
THE-MAN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote THE-MAN Quote  Post ReplyReply Direct Link To This Post Posted: 23 Feb 2014 at 7:28am
You usually only break the nose cone when the timing is too advanced and it kicks back. Half of people's problems is faulty timing.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 23 Feb 2014 at 7:56am
I just love these side-line geniuses who will say something like " you're gonna break nose-cones off your starter" and then offer zero solutions. I've never broken nothing. I always use the later WD-45 gas Delco starter that has a center bearing inside of it to reduce armature flex. There is a better/stronger starter drive available at any good starter/gen/alt repair shop that withstands the "hit" of 12 volts better than the original starter drive. Big battery cables and a good ground are imperative. Correct iginition timing is a must, along with an operator who actually knows where the throttle and choke need to be to achieve a good and quick firing of the engine, instead of constant cranking.
Post Options Post Options   Thanks (0) Thanks(0)   Quote mufflerboltz Quote  Post ReplyReply Direct Link To This Post Posted: 23 Feb 2014 at 8:52am
Thanks for the advice guys. Trying to plan all this stuff out as I took my block and crank down to the shop last week so now trying to round up all the little stuff I'll need.
IL-D17 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IL-D17 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Feb 2014 at 11:14am
Check out hitorque.com and give them a call. they built a starter for my near 12-1 CR 226 engine and it works great. All they need are some engine specifics and a few measurements where the starter mounts and BOOM you gota strong gear reduction starter at your doorstep.
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2014 at 9:04pm
Use a diesel starter.  MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote patrickmull Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2014 at 5:47am
IL-d17 how did you do at the princeton IN natpa pull
Post Options Post Options   Thanks (0) Thanks(0)   Quote cotncrzy Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2014 at 8:55am
Mack,
   I tried the diesel starter, it wouldnt reach the ring gear properly. Should it have been as simple as to "bolt in"?
mgburchard View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mgburchard Quote  Post ReplyReply Direct Link To This Post Posted: 02 Mar 2014 at 7:33pm
The secret from the nuclear power pullers is to run more voltage than amperage. Instead of running 12 volts at 1000cca try 16 volts at 550cca. Up to 24 volts just lower the amp capacity.
Post Options Post Options   Thanks (0) Thanks(0)   Quote IL-D17 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Mar 2014 at 8:39pm
Not worth a darn, I ran in the bottom 3rd of the pack all day. If consistency is worth any thing I was that LOL. It was my fault for trying to run too hi a gear in the 5500 bt I tried it and ran outa ponies. Sooo I came home and tore engine down lol gonna do a lil more to the ol' girl.
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2014 at 8:19am
On a WD you may have to drill a new hole in starter to set at proper depth. It has a tappered hole, but a streight hole will work.    MACK
