Starter for D15
WD45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WD45 Quote  Post ReplyReply Direct Link To This Post Topic: Starter for D15
    Posted: 26 Apr 2016 at 8:16pm
Starter for D15 series II gas Delco Remy part number 1107758.
Does this number cross over for a starter from a different source ?
eg NAPA etc.
Fred Dunlop, G,B,CA, WC,WF, 3 WD45`s,gas, diesel and LP,U,D10 series III, D12,D14,D15 SERIES II,D17 Series IV in Gas and Diesel ,D19 GAS and D21,170 185,210 ,220 an I-600 8070 fwd, 716H and 1920H
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 26 Apr 2016 at 8:25pm
Steve at B&B will know....
be careful.. might be 6 volt or 12 volt.
this is assuming D-15 is similar to D-14...
count teeth on pinion gear 9 teeth=12 volt, 10 teeth 6 volt
I KNOW 6 volt starters for D-14 have metal 'brush band' on them and 10 teeth and will NOT fit a real 12 volt D-14.....
Jay
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Apr 2016 at 9:37pm
All D15s are 12 volt, so no problems there.  A local shop should be able to rebuild yours.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 26 Apr 2016 at 9:39pm
Some times, the hard thing to come up with is the starter nose piece...
