Sprocket liners |
Josh H
Joined: 24 Feb 2015 Location: Carnesville, GA Points: 128 |
Topic: Sprocket linersPosted: 29 Jun 2016 at 6:32am |
I heard pigeon products and manufacturing in garrison, north Dakota
Has them. +1 701-463-2959. Thats what I'll be doing on my machine Although someone said some other segment will worth on 16b. He says Make sure to time sprocket before welding liners. |
CAL(KS)
Joined: 18 Sep 2009 Location: Chapman, KS Points: 3804 |
Posted: 29 Jun 2016 at 8:42am |
arnt 16B's equipped with bolt on segments?
Josh H
Posted: 29 Jun 2016 at 8:44am |
Why can't you use liners on segments. Cut them in half where the segments end
CAL(KS)
Posted: 29 Jun 2016 at 8:51am |
You can. I just thought it was kinda silly to cast liners to weld onto replaceable segments when that is why the were designed : to bolt on new segments not have to weld on rings like the old style. why not cast it as an oem match?
Edited by CAL(KS) - 29 Jun 2016 at 9:07am |
Coke-in-MN
Joined: 12 Sep 2009 Location: Afton MN Points: 42266 |
Posted: 29 Jun 2016 at 10:38am |
Liners or cups can be welded in , yet if the sprocket teeth are worn heavily I would question getting them into proper position so as to contact bushing outer surface.
Seen some attempts at repairing worn sprockets and it seems more trouble that it's worth . I built up top surface on a set of HD5 track welding first with 7018 rod and then a hard surface rod over that - I got about 2 years of life out of the job but ended up replacing sprocket as well as track - I welded on sprocket rings onto old spokes > On my D6 I welded new rings onto spokes to take D5 segmented sprockets - then the rest of machine self destructed before I could get my investment back in the tracks .
Josh H
Posted: 04 Jul 2016 at 10:05pm |
Whats the option besides used because i can't find new parts?
DMiller
Joined: 14 Sep 2009 Location: Hermann, Mo Points: 35655 |
Posted: 05 Jul 2016 at 5:00am |
Conversion to what is available, finding a sprocket of similar diameter in a other make machine and converting the entire undercarriage to that machine series. Idlers can be converted, roller frames re-drilled for different mountings, sprocket ring can be replaced with a different make on the old spokes. Been done to other machines and shown on here. I have that issue with my old 7G, it uses 7" pitch that no one else uses today, IHC did thru the Dresser machines but even they are all gone. So I have a set of spare rails I will use up and either make the attempt to convert or give the old machine up.
Dozer
Joined: 16 Aug 2011 Location: SW New York Points: 689 |
Posted: 06 Jul 2016 at 6:39am |
Sprocket liners # 54 C200 for (2) sprockets for my HD6G $281.50 including shipping
Pigeon Products & Mfg PO box 187 Garrison, ND 58540 (701) 463 2959 |
CAL(KS)
Posted: 06 Jul 2016 at 7:52am |
Henderson MFG in Texas has sprockets for many brands and models. they show for 16 and 16D but not 16B. might be worth a call though. these are new rings
Dozer
Posted: 06 Jul 2016 at 11:09am |
Pigeon Products & Mfg has sprocket liners for HD7G for $312.50 including shipping and for HD11 for $335.50 including shipping.
