SP/AP46 Pistons with WD45 Crank
PA185 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote PA185 Quote  Post ReplyReply Direct Link To This Post Topic: SP/AP46 Pistons with WD45 Crank
    Posted: 04 Mar 2021 at 8:52am
Question about the AP/SP46 M&W, WD45 crank combo.
For the 13:1 compression set up will the factory felpro head gasket hold?
Or do you have to run a copper head gasket with an o ringed head?
Looking for input from people who have ran the set up or are familiar with it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 04 Mar 2021 at 10:08am
I always used a stock OEM head gasket from the old days. Now, todays head gasket isn't the laminated metal one from yesteryear, but I still think you'll be OK. Do a cold retorque after you've run it a couple of times down the track. Ignition timing will need to be retarded somewhat with the higher compression.
steve fischer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve fischer Quote  Post ReplyReply Direct Link To This Post Posted: 09 Mar 2021 at 7:50am
I have run stock gaskets also have some extra ap46 and ap48 pistons
