SP/AP46 Pistons with WD45 Crank |
PA185
Joined: 08 Mar 2019 Location: Pennsylvania Points: 67 |
Topic: SP/AP46 Pistons with WD45 CrankPosted: 04 Mar 2021 at 8:52am |
Question about the AP/SP46 M&W, WD45 crank combo.
For the 13:1 compression set up will the factory felpro head gasket hold? Or do you have to run a copper head gasket with an o ringed head? Looking for input from people who have ran the set up or are familiar with it. |
Posted: 04 Mar 2021 at 10:08am |
I always used a stock OEM head gasket from the old days. Now, todays head gasket isn't the laminated metal one from yesteryear, but I still think you'll be OK. Do a cold retorque after you've run it a couple of times down the track. Ignition timing will need to be retarded somewhat with the higher compression.
steve fischer
Joined: 11 Jul 2011 Location: sleepy eye mn Points: 1018 |
Posted: 09 Mar 2021 at 7:50am |
I have run stock gaskets also have some extra ap46 and ap48 pistons
