So I’m having trouble w d15 center adjusters
Jk chalmers View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jk chalmers Quote  Post ReplyReply Direct Link To This Post Topic: So I’m having trouble w d15 center adjusters
    Posted: 03 Jun 2018 at 7:24pm
It is a series 2 and I have extra 45 ones and they look exactly the same can I just use those I was told I couldn’t but I see absolutely no differences when held up to each other thanks for the responses
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jun 2018 at 7:56pm
The wheel centers are different between the D15 and WD45.  D15 has a flat face while the WD45 is dished.  As a result, the eccentrics are different between the 2 models.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jk chalmers Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jun 2018 at 8:07pm
Dang it I guess it’s a bunch of hammer and torch time ugh thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jun 2018 at 8:28pm
Here's the whole poop on PA wheel clamps...
[TUBE]l2qXT3GGc5w[/TUBE]
Reindeer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Reindeer Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jun 2018 at 9:05pm
I just removed my wheels off a D15.  Getting the centers out was quite a bit of work.  Myself and an exchange student that likes to come by and play in the shop worked ourselves into a pretty good lather trying to pound the centers out the way Dennis shows in the video.  They just bounced, but would not seperate.  In the end I put a bar into the hooked end of the rail, and pried down on the hub, and they came apart fairly easily after all our pounding.
I tried prying with out pounding on the center on the second one, but they needed to be broken loose with pounding before trying to pry them out.  I had to add some material under the bar to get the fulcrum where it needed to be, but it was comically easy after an hour and some of slamming the hub with an eight pound maul.Cry
Edited by Reindeer - 03 Jun 2018 at 9:06pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jk chalmers Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jun 2018 at 9:09pm
Centers were not to bad for me it’s staring to break apart the part that tightens centers down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jk chalmers Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jun 2018 at 8:02pm
Success guys with a lot of patience and a lot of work I freed them all up thank god that’s done wire wheel kill rust and paint and done w em
copyrite1972 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote copyrite1972 Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jun 2018 at 9:35pm
Now that you've had some practice, you should have no problem doin' mine!! LOL
D15 Series II
Lon(MN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lon(MN) Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jun 2018 at 7:31am
Parts book shows the same part number for the eccentric. 28, 38, and 26 inch rim.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jk chalmers Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jun 2018 at 4:30pm
Well bring em over w some cash and I’ll bust em out :)
