snowblower for Allis D-17
TonyF View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TonyF Quote  Post ReplyReply Direct Link To This Post Topic: snowblower for Allis D-17
    Posted: 17 Apr 2022 at 2:45pm
I have a 6 foot Loftness snowblower on my Allis D-17. I'm a hobby farmer without much experience in these things, so am always looking for advice. My uncle has had D-17s since the early '60s. He says my blower is too heavy for the tractor and could end up breaking one of the 3 pt arms. I have no idea about how much my blower weighs. It's an older blower, and looks pretty heavy duty. Is there a particular brand of blower I should use with my D-17? Last thing I need is to break a 3 pt arm. I see that Northern Tool sells a 6 foot NorTrac blower that weighs over 700 pounds. Is that too much weight for a blower on a D17?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 17 Apr 2022 at 4:27pm
Not having seen either your blower, or your tractor, Its hard to diagnose from afar.  Hows about more info?  What series tractor, what brand blower or some pictures would go a long way toward answering your questions.  Oh, and welcome to the forum!Hug
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 17 Apr 2022 at 6:35pm
If it is a series 4  D-17, the hitch ruggedness is the same as a 190XT, so I think your Uncle is wrong. You might need some front end weight ? You could have a HP issue but that is remedied by less than 6 ft cuts or holding the blower off the ground for a ways and then taking a second swipe.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matt (Jordan,MN) Quote  Post ReplyReply Direct Link To This Post Posted: 17 Apr 2022 at 7:47pm
We have had a 6ft Loftness blower on D17's since 1988 and have had no problems. Its been on 2 series 1's and currently is on a series3 so its a aftermarket / homemade 3 point not factory. It can get a little light in the front and you have too slip the hand clutch to regulate the speed but works good.
Owner of Matt Scott LLC
http://www.mattscottllc.com/
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 17 Apr 2022 at 7:53pm
If the front end will stay on the ground,  and hydraulics will lift it, you won't hurt the 3 point.                   MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 17 Apr 2022 at 8:41pm
I agree with the others. Nothing to worry about. I have a 6ft other brand(brand name I forgot but popular) on my 45 with modified aftermarket 3pt. little light on the front with 2 F&H rear wheel weights mounted on the front but no issues for many years.
This page was generated in 0.081 seconds.
