Snow Bee snowblower drive ?
Freewheelin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Freewheelin Quote  Post ReplyReply Direct Link To This Post Topic: Snow Bee snowblower drive ?
    Posted: 30 Aug 2015 at 10:07am
I restored an Allis Snow Bee snow blower a few years ago. It worked fine until this month. Now the drive doesn't work in forward or reverse. The case with the planetary gears turns but not the axle shaft. I pulled the drive axel and it appears as though there must be some sort of friction drive as there are no gears, splines, etc. Does anyone have knowledge of these units or a schematic? Any help will be greatly appreciated.
Lars(wi) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lars(wi) Quote  Post ReplyReply Direct Link To This Post Posted: 30 Aug 2015 at 10:58am
more than likely the same drive that on the 'mow bee', also the same as some early simplicity riding mowers. Hann-Eclipse was the manufacturer for the mow-bee, if you can get the info for the model 200 its the same. Ariens models used the same system at one time.
talntedmrgreen View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote talntedmrgreen Quote  Post ReplyReply Direct Link To This Post Posted: 31 Aug 2015 at 8:47am
Hahn made some of the blowers, as did Gilson.  I think the Hahn's were the only ones with the friction type drive though.
Patterson B1*B1/B1Forklift*B10*BigTen/B1Loader*B110*B208*B206*616*Homelite T16H/T8/T7/RM7E*Landlord/Loader/Trencher*Broadmoor717*Serf525*2110*7790*Legacy XL*Twin 20*Squire9*Squire6*JCPenny 494
This page was generated in 0.234 seconds.
