Snap coupler model 73 plow
wildcat2 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wildcat2 Quote  Post ReplyReply Direct Link To This Post Topic: Snap coupler model 73 plow
    Posted: 18 Aug 2015 at 6:47pm
Does anybody know which black paint AC used on the plow bottoms, gloss, semi-gloss, or flat? I am restoring the plow to go behind my D-17.
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 18 Aug 2015 at 9:19pm
Flat black.  Soft paint should be used if you intend to do any plowing with it.  Soft paint is usually that color.
Edited by DSeries4 - 18 Aug 2015 at 9:19pm
Butch(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Butch(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 19 Aug 2015 at 6:37am
If you are after a proper look then the bottoms should be painted #2 orange not black. The black bottoms came along with the 2000 series and as I remember even the earlier 2000s had orange bottoms.
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 23 Aug 2015 at 8:05pm
An Allis 73 I saw yesterday at the Homer Iowa Show. Looks like its never been painted. The plow bottoms are flat black probably the black oxide from heat treatment, not paint. We'd want to paint the wear surfaces (grease if inside except when plowing) to keep them from rusting. A soft paint (cheap spray paint or special plow paint) wears off quickest when actually plowing. Grease even inside won't last much more than a year. On a hot summer day it melts and runs off.
Gerald J.
Post Options Post Options   Thanks (0) Thanks(0)   Quote wildcat2 Quote  Post ReplyReply Direct Link To This Post Posted: 24 Aug 2015 at 8:11am
Thanks for the reply's. When cleaning mine up there are some paint runs and lots of rust, but couldn't make out which shade of black it was.
Don(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 24 Aug 2015 at 8:36am
I have a later ser# 73 with black painted bottoms. I don't know the color of black just that AC painted the newer bottoms black. I will guess semi gloss black.
