small front tires on a WD puller
cotncrzy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cotncrzy Quote  Post ReplyReply Direct Link To This Post Topic: small front tires on a WD puller
    Posted: 26 Jan 2013 at 11:50am
Is there an advanage to lowering the front end of the tractor? I could loose a few pounds this way. I am going to re do the front weight bracket, smaller tires will affect my design, so I GOT TO MAKE MY MIND UP.
Edited by cotncrzy - 27 Jan 2013 at 6:39pm
C, WD45,WD puller, 185, 200, 7060 Red Belly, 7060 Black Belly,8010, and a R52 Gleaner, AND PROUD OF THEM!
Mrgoodwrench View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mrgoodwrench Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2013 at 12:03pm
i think we need a little more info cot...lol!
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jan 2013 at 10:12am
2
SF Fan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SF Fan Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jan 2013 at 10:21am
3
mlpankey View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jan 2013 at 5:26pm
I like rake.
cwhit View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cwhit Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jan 2013 at 6:46pm
The answer is yes. It has to do with leverage.
Post Options Post Options   Thanks (0) Thanks(0)   Quote cotncrzy Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jan 2013 at 6:00am
Ok this is what I wanted... Don't stop now!   I assume with the front lower, it will take more force on the rear to lift it until it gets to a ceartin point??????
Edited by cotncrzy - 29 Jan 2013 at 6:11am
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jan 2013 at 6:26am
Whenever the front has been dropped down below centerline, as you begin to raise the front wheels off the ground, the front weights actually start moving forward a bit making the front heavier/harder to lift. The lower it is dropped the more this has an effect.
WildBill View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WildBill Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jan 2013 at 2:12pm
Cotn , put about a 3 or 4 degree rake on it. use an magnetic angle finder place it on center of engine . Maybe between the 2 water jackets on the cylinder head . Then see where ur at. Be careful at rules etc. There is a sled in the area where I live that disqualifies over 18 inches of lift. That sucks! But it's a hook. Take care .
Allis fan for life !   B,C,2-WC'S,WD45G,D19G,190xt ,LLSS 8010, terra tiger refurbished
d17brown View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote d17brown Quote  Post ReplyReply Direct Link To This Post Posted: 01 Feb 2013 at 7:43am
i have a set of rc wheels for sale, they are 15 inch run them on my puller
phil
Post Options Post Options   Thanks (0) Thanks(0)   Quote cotncrzy Quote  Post ReplyReply Direct Link To This Post Posted: 01 Feb 2013 at 7:51am
  What will fit? Is the pattern 5 hole x 4.5 or 4.75? Any automotive wheel fit? I am away from the tractor cant go measure. May be able to find something at a salvage yard, I have an old axle, with a set of 12" wheels on it, I think they are 4.5" pattern. I would like to go aluminium, and look pretty! LOL!
farmer_rob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote farmer_rob Quote  Post ReplyReply Direct Link To This Post Posted: 02 Feb 2013 at 6:49am
I replaced my originals from my wd45 with ones from a farmall cub. I cut out the centres out of the cub rims and welded in ones from the spare 45,s . I did this for two reasons. 1 i wanted to lose some weight. So I thought of removing on tire but was not allowed. By using the 4x12 cub they are 18 lbs whereas the 45's are 52lbs each. Lost 68lbs instead of just 52lbs. Just following rules lol. 2 is leverage just like doc said I figured it would be harder to lift therefore I would infect be further down track before she started to lift
if farming was easy everybody would be doing it
Post Options Post Options   Thanks (0) Thanks(0)   Quote farmer_rob Quote  Post ReplyReply Direct Link To This Post Posted: 02 Feb 2013 at 6:51am
I forgot to mention I have 12.6x38's on the rear
