sleeve "O" rings |
Post Reply | Page <12 |
kendak
Bronze Level Joined: 22 Sep 2009 Location: boyle, miss. Points: 37 |
good run Mitch ...they still don't get it
Dick L
Orange Level Joined: 12 Sep 2009 Location: Edon Ohio Points: 5087 |
Lots of opinions without knowing what they are talking about. Plankeys chart would be some help if you click on the material. They will not give away their total formulas.
I have a gaylord of EPDM rubber in my warehouse. EPDM rubber aint worth squat until you mix other things with it. If I go up and open it up it will be one big 500 pound glob.
When I use it I add a curing agent and mix it with polypropylene as the main carrier along with other things that I will not share. EPDM rubber is always mixed in as part of a formula which can change it to withstand different chemicals. It is the rubber part of the formula and will not withstand much by its self.
GBACBFan
Orange Level Joined: 11 Sep 2009 Location: Green Bay WI Points: 2662 |
What I do get is that this post is less about O rings and more about business. You're upset with a vendor because you now think you made a bad buy decision before you researched an item. If you buy your groceries at store "x", buy bananas at $.69/lb, stop at store "Y" on the way home to get meat and find out this store has bananas for $.35/lb, do you go back to the first store and demand a refund because their bananas are twice as expensive as the second store?
It seems nobody wants to take responsibility for their own actions anymore. It's always someone else's fault. If reducing cost to the lowest penny is your driving factor, maybe rubber bands would be a good substitute for O rings. They can be found for free.
are genuine." - Mark Twain |
kendak
I think since everyone has been so helpful I'll just put a bead of hi-temp silicone on them & leave the rings off...ran [3] years that way as a stock puller till I dropped a valve
Jamie NC
Silver Level Joined: 11 Sep 2009 Location: Conover NC Points: 319 |
Sounds good to me!! go for it!!
Allis tractor puller CA WC WD D17
kendak
no you are wrong ...what upsets me is the fact that a .06 "O" was marked up to $5.12 & you are right I didn't check prices because I have bought from them before & always thought they were on the up & up...like I said in the first post it's called stupid tax ..shame on me for trusting someone
Gerald J.
Orange Level Joined: 12 Sep 2009 Location: Hamilton Co, IA Points: 5636 |
And the material in that .06 ring may last the first time you run the engine. O-rings for sleeves tend to not stand oil well, to the point that using an oil rather than an approved soap to lubricate them at assembly causes rapid deterioration. But they stand up to antifreeze, both types, heat and vibration. Rings that stand up to oil are used in hydraulics and aren't affected by being immersed in oil, different material that those for sleeves.
Gerald J. |
mlpankey
Orange Level Joined: 13 Sep 2009 Location: Vols country Points: 4580 |
use dow corning 111 silicone grease on all o rings that are being assembled and have no deteriation of any material that o ring was produced by . Its stands to reason that any chemical used on material that isnt chemical resistant to the chemical being applied to material causes deteriation.
CJohnS MI
Orange Level Joined: 27 Jun 2010 Location: Lapeer MI Points: 326 |
Yup, I used to think that too, and did use silicone spray and grease on a lotof stuff: Source: http://www.advantageengineparts.com/ Nowadays, I use exactly the same stuff as I did with my first sleeve job: "soapy water solution", otherwise known as Murphy's Oil Soap. Some fellas I know prefer Palmolive (they like to keep their hands silky smooth). The other thing that matters and isn't mentioned in the quoted article, is "stiction". Since whatever lube used is in a confined space, and not subjected to a lot of flow, it stays around in that location a long, long time. And here's the deal - Silicone lubricates REALLY well. Which sounds good except: doing that allows the face of the seal to move against the bore it rests in - and that ain't good. Every time that cylinder fires, and that piston moves up and down, there's a tendency for the sleeve to move too. Well, that head and gasket holds it in place pretty well - but not absolutely - there is still micro thousands of motion going on. What the goal of the o-ring fitting properly is - that it fill the groove its fitted to, then have enough "stiction" to grab the outer bore. What's left is that the o-ring material in the middle flexes - along the same line as holding a wad of sticky bread dough between your hands, then rolling it up and down - the outer bread dough sticks to your hands, and the dough in the middle has to move. This way, the outside diameter of the o-ring isn't abraded away from that micro-motion of the sleeve in the bore. A hydraulic cylinder goes up and down a few times a day. An actuator valve cycles a few times a day. The seal at a hydraulic fitting relies on static adjustable compression. But an engine at 1400 rpm (or 5000) man, that adds up really fast. Edited by CJohnS MI - 02 Sep 2010 at 12:50pm |
mlpankey
Ih have several promblems. http://www.dowcorning.com/content/news/iam_news32.asp
