Sickle Mower
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Topic: Sickle Mower
    Posted: 21 Feb 2011 at 10:00am
Will an 80R sickle mower cut grass nicely?  Rather than a belly mower, which I can't find for a WD45, can I use one of these?  Has anyone tried this?
GregLawlerMinn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GregLawlerMinn Quote  Post ReplyReply Direct Link To This Post Posted: 21 Feb 2011 at 10:07am
The sickle mower cuts grass nicely. It's purpose is to cut longer grass for making hay. It won't replace a lawnmower as it does not "chop up and throw out" the cut grass. I have used mine to cut long grass and weeds where it is not important to remove the cuttings
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 21 Feb 2011 at 10:12am
If you want to maintain an area with a sickle mower, clip it at regular intervals so it doesn't get too tall. Keeping the sickle up off the ground a couple inches will help keep previous clippings from plugging the mower. The sickle mower will be faster and you will use less fuel, but it won't look like a lawn mower job.
